QNAP - Serviio don't Start "ffmpeg missing"
naonilio
Post Sat Oct 15, 2022 1:04 pm
Serviio works like a charme seems years on my qnap 253A.
I updated to QNAP OS 5.0.1 and revert back to 5.0.0 due to issue with version > 5.0.0 QNAP OS and Serviio.
In 5.0.0 I have now issue, Serviio won't start and in Logs I have this :
2022-10-15T15:11:14,127 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/share/CACHEDEV1_DATA/.qpkg/Serviio/ffmpeg": error=2, No such file or directory
java.io.IOException: Cannot run program "/share/CACHEDEV1_DATA/.qpkg/Serviio/ffmpeg": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048) ~[?:1.8.0_151]
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:136) [serviio.jar:?]
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method) ~[?:1.8.0_151]
at java.lang.UNIXProcess.<init>(UNIXProcess.java:247) ~[?:1.8.0_151]
at java.lang.ProcessImpl.start(ProcessImpl.java:134) ~[?:1.8.0_151]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029) ~[?:1.8.0_151]
... 1 more
2022-10-15T15:11:14,235 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: FFMPEG not found. Serviio will not work properly.
java.lang.ExceptionInInitializerError: null
at org.serviio.MediaServer.main(MediaServer.java:147) [serviio.jar:?]
Caused by: java.lang.RuntimeException: FFMPEG not found. Serviio will not work properly.
at org.serviio.external.FFMPEGWrapper.loadFFmpegInfo(FFMPEGWrapper.java:123) ~[serviio.jar:?]
at org.serviio.external.FFMPEGWrapper.<clinit>(FFMPEGWrapper.java:96) ~[serviio.jar:?]
... 1 more
I have ffmpeg 5.0.1.1 installed on my qnap and a file named ffmpeg is in /share/CACHEDEV1_DATA/.qpkg/Serviio/ directory.
Tried to delete and install both serviio and ffmpeg but still have the same issue again and again.
Can I have some help please :)
naonilio
Post Sun Oct 30, 2022 8:47 am
Re: QNAP - Serviio don't Start "ffmpeg missing"
For info : issue is gone with 2.3 version. works like a charm again.
