[Need help] to install serviio 2.3 in QNAP TS-451+
attticus76
Post Thu May 02, 2024 10:45 pm
Hi. I have QNAP TS-451+ with QTS 5.1.6.2722
I can manually install the version of Serviio (Serviio_2.3_x86_64.qpkg) without a digital signature.
When I open Serviio, it opens a tab with the IP of the QNAP followed by "/:23523/console/" but I always get an ERR_CONNECTION_REFUSED.
Is there anything I can do?
Post Fri May 03, 2024 1:46 pm
Re: [Need help] to install serviio 2.3 in QNAP TS-451+
In the link there should not be a / between the IP address and the semicolon and port number. Just to make a hypothetical link example, it should be HTTPS://192.168.2.2:23523/Console. Also, the port number you copied is only for a secure (HTTPS) connection. I can't recall the specifics about activating HTTPS on the console, so you might instead try using 23423 for the port number. If HTTPS isn't enabled for your console, that would also explain why you're getting a rejected connection message.
attticus76
Post Fri May 03, 2024 3:34 pm
atc98092 wrote:In the link there should not be a / between the IP address and the semicolon and port number. Just to make a hypothetical link example, it should be HTTPS://192.168.2.2:23523/Console. Also, the port number you copied is only for a secure (HTTPS) connection. I can't recall the specifics about activating HTTPS on the console, so you might instead try using 23423 for the port number. If HTTPS isn't enabled for your console, that would also explain why you're getting a rejected connection message.
Sorry, I wrote the URL wrong. It would be as you say, 'https://IP_NAS:23523/console'. That's the one that opens when clicking on the Serviio icon.
I've also tried
'http://IP_NAS:23523/console',
'https://IP_NAS:23423/console',
'https://IP_NAS:23523',
'https://IP_NAS:24523'
without success.
Should I check something in the QNAP configuration?
Post Fri May 03, 2024 3:36 pm
With the 423 port, you can't use HTTPS. It has to be http://IP_NAS:23423/console
attticus76
Post Fri May 03, 2024 3:38 pm
atc98092 wrote:With the 423 port, you can't use HTTPS. It has to be http://IP_NAS:23423/console
Just I checked it, the url "http://IP_NAS:23423/console" without success
Post Fri May 03, 2024 3:54 pm
OK, I've reached my limit of assistance, as I have no experience with a NAS device install. If you can see the Serviio process running on the device (I have no idea how you do that with a NAS) then something in the install isn't correct. If you can't see the process running at all, then you need to determine why it's not running. Serviio creates a log file that might provide some answers, but again on a NAS I can't tell you where that log might be found.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 25 guests
