[CDS API] - Playing back transcoded Audio
Post Tue Sep 04, 2012 6:29 pm
First question, is the content length for transcoded audio always 900000000 (I need to detect whether I can give a progress update based on percentage)
Second question is more implementation, what is the best way to detect when I have finished downloading the complete audio file?
I have the following in a loop, but inputStream.read(buf) doesn't return on the final (or I suppose final+1) read. Looking online, I either need to know the content length, which won't happen, or the server needs to close the connection.
while (true) {
   int numread = inputStream.read(buf);
   if (numread <= 0) {
      success = true;
      break;
   fileStream.write(buf, 0, numread);
   mTotalBytes += numread;
   update progress
Post Wed Sep 05, 2012 9:15 pm
Re: [CDS API] - Playing back transcoded Audio
The 90000000 is a randon length, needed by Http 1.0 DLNA renderers, who don't support chunked encoding. I *think* the connection should close, can you try with wget or similar?
Post Wed Sep 05, 2012 9:21 pm
Ok, I don't mind what it is, I just need a consistent way to tell if the file is being transcoded right now, or if it is native/from an already transcoded file. Is there a better way to detect it?
I'll try wget in the morning to see if that sheds any light. (The code works fine for non transcoded audio)
Post Wed Sep 05, 2012 9:24 pm
For DLNA Serviio sends CI value of 1 in the protocol info for file that is being transcoded and 0 for file that is played natively or already is fully transcoded. I guess I could add another attribute to the API to mimick this.
We can talk about it later. For now you can check for the 900000... value, as a hack.
Post Thu Sep 06, 2012 8:35 pm
Doesn't look like it closes the connection, wget downloads the file then hangs.
wget http://192.168.15.100:23424/cds/resource/17962/MEDIA_ITEM/MP3-0/ORIGINAL,serviigo?authToken=3b35f135f2c3425c88e363f2780445d7
--2012-09-06 21:26:07--  http://192.168.15.100:23424/cds/resource/17962/MEDIA_ITEM/MP3-0/ORIGINAL,serviigo?authToken=3b35f135f2c3425c88e363f2780445d7
Connecting to 192.168.15.100:23424... connected.
HTTP request sent, awaiting response... 200 OK
Length: 900000000 (858M) [audio/mpeg]
Saving to: `ORIGINAL,serviigo?authToken=3b35f135f2c3425c88e363f2780445d7.2'
 0% [>        ] 5,383,131   --.-K/s  eta 2h 28m
Post Thu Sep 06, 2012 11:34 pm
I have now fixed this, hopefully not breaking anything else ;-) Do you need a build? I'm away for the weekend but could send you one next week.
Post Fri Sep 07, 2012 6:50 am
A build next week would be good, thanks.
