Web UI installation help
pedenski
Post Mon May 27, 2013 3:31 pm
Wiki ( http://wiki.serviio.org/doku.php?id=phpwebui ) installation seems to be incomplete. can someone help me the steps on making the WEB ui work?
after i download the latest version v1.4, extract the files inside /var/www
and then whats next?
Post Mon May 27, 2013 3:38 pm
Re: Web UI installation help
Assuming you installed all the needed compontents, and for example, extracted the files to /var/www/serviioweb (you may have made a different folder/extracted the files directly into /var/www), you you simply visit http://server_ip/serviioweb (or http://server_ip/ if you extracted the files directly into /var/www )
pedenski
Post Wed May 29, 2013 8:23 am
Hi Will,
I created /serviio folder inside /var/www
extraced all files inside /var/www/serviio
run apache service
typed-in the ip address on my browser http://192.168.1.10/serviio
but it shows a blank page.
MiamiGUY
Post Sat Nov 02, 2013 7:54 pm
I have downloaded the file:
wget https://github.com/SwoopX/Web-UI-for-Se ... io-1.3.zip
unzip Serviio-1.3.zip
mv Web-UI-for-Serviio-Serviio-1.3 serviio
Type the address on FireFOX and hit enter
http://192.168.1.20/serviio/index.php
I get a blank page - source code of the page is also blank
Note: Servvio is running fine
Swoop
Post Sun Nov 24, 2013 10:58 pm
You might check if the file and directory permissions are adequate to access the content.
