Web UI available running IIS 7 / Windows 7
slingshot
Post Thu Apr 14, 2011 8:17 am
I see here there is a Web UI available here for PHP. Is there also a variant which I can use on windows 7 / IIS.
Or is it possible to run the php Web UI on IIS?
Post Thu Apr 14, 2011 8:21 am
Re: Web UI available running IIS 7 / Windows 7
slingshot
Post Thu Apr 14, 2011 8:29 am
zip wrote:I guess. http://php.iis.net/
Thanks I try this and post if it works!
slingshot
Post Thu Apr 14, 2011 8:33 am
It can not be installed with the previous link on windows 7.
I found a video, will try this later http://www.youtube.com/watch?v=APk6P0sxX5U
evanslee
Post Thu May 05, 2011 11:06 pm
Use this link instead
http://www.microsoft.com/web/platform/phponwindows.aspx
"PHP now runs better than ever on Windows. Utilize the power of IIS 7.0 and the Windows Web App Gallery. Improve speed and efficiency with Fast CGI and WinCache."
http://www.microsoft.com/web/gallery/install.aspx?appid=PHP52
http://www.microsoft.com/web/gallery/install.aspx?appid=PHP53
