Alternative to ffmpeg for live streams
piscui
Post Sat Feb 04, 2012 5:07 am
Is there a way to use something other than ffmpeg to pipe in the video stream data? Or is it possible to do that via plugins?
That would be really cool because you would not only be able to stream non-standard streams in some proprietary format but also use other tools such as rtmpdump. Porting streams from other tools (rtmpgui, xbmc, etc) would also be much easier.
Post Sat Feb 04, 2012 5:14 am
Re: Alternative to ffmpeg for live streams
rtmpdump is already being used with ffmpeg, it ffmpeg is configured to use it.
this wiki entry shows what all programs ffmepg is setup for.
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
piscui
Post Sat Feb 04, 2012 7:38 pm
I think what you're referring to is librtmp. It is my understanding that both ffmpeg and rtmpdump make use of this library, however with different implementations.
My question aims to be able to use either tool (not just the library), or any tool for that matter that can output a video stream data.
Post Sat Feb 04, 2012 7:48 pm
piscui wrote:I think what you're referring to is librtmp. It is my understanding that both ffmpeg and rtmpdump make use of this library, however with different implementations.
no serviio is designed around ffmpeg so nothing else can be used.
piscui
Post Sat Feb 04, 2012 9:07 pm
Is it too much of a long shot to request this as a new feature?
Post Sat Feb 04, 2012 9:39 pm
piscui wrote:Is it too much of a long shot to request this as a new feature?
yep
piscui
Post Sat Feb 04, 2012 10:33 pm
yep
@Cerberus: Thanks.
@zip: would you please confirm this?
Post Sat Feb 04, 2012 11:18 pm
no plans not scope for doing this atm
piscui
Post Sat Feb 04, 2012 11:53 pm
Got it, I'll figure something out then - thanks.
