Sweflix - Movies in HD (not US/UK)
Iveky
Post Fri Oct 23, 2015 4:57 pm
Re: Sweflix - Movies in HD (not US/UK)
sweflix now asks for captcha, so impossible to work reliably for longer period.... (my oppinion).
lycanknight
Post Fri Oct 23, 2015 5:33 pm
Iveky wrote:sweflix now asks for captcha, so impossible to work reliably for longer period.... (my oppinion).
was thinking that myself but i have the log where it threw off warns if interested i don't know if you would like whole log or just parts where warns were at
    2015-10-23 09:34:33,760 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://sweflix.to/genre/senaste/, will try again soon: Unexpected error while invoking plugin (Sweflix): Server returned HTTP response code: 403 for URL: http://sweflix.to/genre/senaste/
    org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (Sweflix): Server returned HTTP response code: 403 for URL: http://sweflix.to/genre/senaste/
    at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
    at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
    at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
    at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
    at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
    Caused by: java.io.IOException: Server returned HTTP response code: 403 for URL: http://sweflix.to/genre/senaste/
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1839)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1440)
    at sun.net.www.protocol.http.HttpURLConnection$getInputStream.call(Unknown Source)
    at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
    at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
    at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112)
    at Sweflix.extractItems(Sweflix.groovy:29)
    at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
    at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
    at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
    at java.util.concurrent.FutureTask.run(FutureTask.java:266)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
    ... 1 more
lycanknight
Post Sat Oct 31, 2015 6:18 pm
dang still not working for me warning if its working for you change nothing cause then it will stop thats what i did i changed my links and bam nothing worked changed them back still no dice did everything i know to do to fix it the only real other thing i did was got a static ip from dnsexit i think its called and i stopped that for a bit or at least i think i did to test that with no luck if anyone finds a fix please share ofcourse this could all be me so that bites if true :cry:
stefana888
Post Sat Jan 02, 2016 10:28 pm
Police raid at Sweflix December 2015. Site down.
Previous
Return to Available plugins
