BBC iPlayer (UK only)
Post Thu Sep 22, 2011 7:59 pm
iPlayer plugin (requires Serviio 1.6.1 and newer)
This is a plugin that enables to watch iPlayer content using the following URL structures:
Categories
http://www.bbc.co.uk/iplayer/categories/documentaries/highlights
http://www.bbc.co.uk/iplayer/categories/documentaries-history/highlights
Groups / collections
http://www.bbc.co.uk/iplayer/group/b06z98k4
http://www.bbc.co.uk/iplayer/group/p02j4np8
Episodes (id comes from the programme URL)
http://www.bbc.co.uk/iplayer/episodes/b006m86d
Added 22/9/2011
Updated for 0.6.1 5/1/2012
Updated 14/12/2012 (thanks to pineson)
Updated 9/6/2013
Updated 30/3/2016
Updated 29/06/2016
IPlayer.groovy
(15.35 KiB) Downloaded 1972 times
Post Wed Mar 30, 2016 8:07 pm
Re: BBC iPlayer (UK only)
Updated the plugin
markstuartwalker
Post Tue May 31, 2016 4:45 am
Thank you this plugin - it works great for the episodes that I want but I am struggling to get the categories function to work.
http://www.bbc.co.uk/iplayer/categories ... highlights
Have the BBC moved things around and broken things?
markstuartwalker
Post Fri Jun 03, 2016 7:04 am
I have looked at the Groovy code and can trace that there is a function to handle categories but I cannot get the logging to work to diagnose any further.
This is likely to be a novice problem. Can anyone help me with this?
Xmantium
Post Sun Jun 12, 2016 9:11 pm
Episodes work fine, cant get categories to work.
markstuartwalker
Post Mon Jun 13, 2016 7:31 am
Agreed. Same as my problem.
Post Tue Jun 21, 2016 1:14 pm
What URL are you using for categories?
markstuartwalker
Post Tue Jun 28, 2016 1:55 pm
See my post above
Doesn't retrieve anything for me
Post Tue Jun 28, 2016 9:06 pm
Try this URL (instead of the grid, it's the a-z link on top right)
http://www.bbc.co.uk/iplayer/categories ... ?sort=atoz
markstuartwalker
Post Wed Jun 29, 2016 7:06 am
Excellent! That fixed that example.
But the one that I was really trying to access was
And that must be different in some way as I get nothing.
I finally worked out how to look at the logging and realised that an exception was being raised when converting the release date. The BBC were being a little lazy in just putting in '1958' instead of '14 Feb 1958' and this was breaking the SimpleDateFormat parsing.
def releasedMatcher = li =~ '(?ms)<span class="release">.*?First shown:\\s*(.*?)\\n.*?</span>'
if(releasedMatcher) {
String releaseDateString = releasedMatcher[0][1]
releaseDate = new SimpleDateFormat('dd MMM yyyy').parse(releaseDateString)
I bodged in a fixed date and this solved the problem (except of course they all now show the same date). I'll let the author fix this more elegantly.
releaseDateString = '1 Jan 1958'
markstuartwalker
Post Wed Jun 29, 2016 10:54 am
Finally, the adoption of all?sort=atoz introduced a fault on the pagination mechanism. I had to add the third line here to suppress an '&amp;' in the URL.
pageBaseUrl = lastPageMatcher[0][1]
totalPages = lastPageMatcher[0][2].toInteger()
pageBaseUrl = pageBaseUrl.replace('amp;','')
Post Wed Jun 29, 2016 7:23 pm
I've fixed the first bit, cannot reproduce the error with pagination - works for me. Updated the plugin in the top post.
markstuartwalker
Post Thu Jun 30, 2016 1:10 pm
Thank you. I have confirmed that date is fixed. You might like to consider modifying other parts of the code where the same date parsing is done.
Try http://www.bbc.co.uk/iplayer/categories ... ?sort=atoz
And observe the first page collecting alphabetically (approximately A-G) and then collecting the first page again rather than page 2.
Enhancing the logging to log("Loading page " +'http://www.bbc.co.uk' + pageBaseUrl + page)
shows the incorrect URL being used.
http://www.bbc.co.uk/iplayer/categories ... amp;page=2
when it should be
http://www.bbc.co.uk/iplayer/categories ... toz&page=2
I suspect that you somehow aren't using the sort=atoz parameter to force the screen to a simple list.
Post Thu Jun 30, 2016 7:10 pm
Thanks, updated
markstuartwalker
Post Fri Jul 01, 2016 11:41 am
Fixed! Thank you.
JamezG
Post Tue Oct 04, 2016 4:58 pm
Hi, As I am now unable to get BBC Iplayer on my Sony Bravia TV (KDL-40EX703), I am trying Serviio ( Prov1.7) to provide access but I am encountering a few problems and I therefore need some help. I have followed the instructions in your posts thank you very much (downloaded the .groovy files, Inserted the URLs as written as a web resource) but:
1. The Episodes elements (including trying the Eastenders Example as written) does not show any episodes. My TV shows the online Display Name in the 'Online' folder but when I select that folder I get ' There are no items to display'
2. The Categories elaments work to a degree but I only get the the first page of files (as shown on the PC iplayer page) displayed on my TV. I have been using the '/all?sort=atoz' parameter at the end of the url but I do not have any item on the screen to select further pages
PS why can I not paste URLs in to the Serviio Console librarys?
kdp99
Post Tue Dec 10, 2019 10:01 pm
Anyone give me a bit of help, I am almost there but not quite with this my first use of a plugin.
I have put the plugin in the plugins folder, then in the consul I have gone to the library then online sources. From there I have said
web resource, and videos,
and in source URL
under presentation for video I have for online display category.
When I go to serviio under video I have an online section, but when I chose it there is no content there.
I am sure I am not quite understanding the process correctly, can some one spot my errors ?
Many thanks.
I have done a few changes but still no joy,
I changed the type to live stream and used the URL below
When I check the URL I get
The stream URL is not valid or is not currently available
kdp99
Post Thu Dec 12, 2019 6:25 pm
Bump !
Return to Available plugins
