live streaming from belize
Firoj
Post Tue Jul 13, 2021 8:41 pm
i have tried several links in serviio online resource for audio streaming and i cannot get it to work ? this is the streaming link --- i can us the same link in VLC player and it works. i have use this link and it works but the others that i have tried does not work in serviio but work in VLC. help??
https://19216801.onl/ https://routerlogin.uno/
Post Tue Jul 13, 2021 11:58 pm
Re: live streaming from belize
Some online streams require a plug-in of some sort. VLC has processing built into it, since it's a player. And a quite good player. But for Serviio to be able to receive the stream and send it back out properly, it needs to be in a certain format, otherwise it needs to be transcoded. I've never played with plug-ins, so I can't say what might be necessary to make it work. You might download one of the plug-ins for another online provider and see if you can use it as a guide to creating one for your stream.
See this topic for some help creating a plug-in. viewtopic.php?f=22&t=3274
Return to Available plugins
