Tune In radio
a7mag3ddon
Post Sat Jun 15, 2019 7:23 am
Re: Tune In radio
Im using a Synology nas.
Windows is easy.
Paul C
Post Tue Jan 21, 2020 2:55 pm
Re: Tune In radio
Is the tunein.groovy plugin currently working in Serviio v2 ?
Downloaded the (latest?) from the first post and installed.
Tried 3 options in Online Sources and playing in the MediaBrowser.
Used Web resource/audio ?
https://tunein.com/radio/Capital-London-958-s16534/ - did not appear in mediabrowser (note it works if you put the link into a browser)
https://tunein.com/radio/Christmas-UK-s298937/ - did not appear in mediabrowser
http://tunein.com/search/?query=capital - appeared in mediabrowser and displayed ten Capital stations - then played wrong station but OK now (after plugin change!).
Under DLNA nothing played.
Post Sun Feb 09, 2020 8:04 pm
Re: Tune In radio
I've updated the plugin a little bit, try it again
yardern
Post Wed Apr 15, 2020 9:24 pm
Re: Tune In radio
First of all, thanks for this great software!
I have tried to use this Plugin for Tunein under Windows 10 as server, somehow I could only see empty folder of it on client.
Maybe it needs an update?
BYW, is there a chance to put in username and password of one's Tunein account like the VLC extension?
Thanks again!
Paul C
Post Mon Jun 08, 2020 1:48 pm
Re: Tune In radio
zip wrote:I've updated the plugin a little bit, try it again
Is the updated plugin you referred to on the first post of this topic (I presume) ?
Still getting the same results as my post above.
TheDoctor
Post Sun Oct 18, 2020 7:33 pm
Re: Tune In radio
I fixed the plugin, now all links to radiostations work. Also added support for "Trend" and "Local" radiostations. As a test, i added "now playing" in addition to the description for each radiostation. In my Firefox browser, "now playing" is not updated after refreshing the page, but after a while the track names are updated automatically. I am working on this question.
Worked (example):
https://tunein.com/radio/Dubstep-g2801/
https://tunein.com/search/?query=Electro
https://tunein.com/radio/trending/
https://tunein.com/radio/local/
TuneIn.groovy
Added support for "Trend" and "Local" radiostations + add "now playing" info.
(5.72 KiB) Downloaded 3539 times
TuneIn.groovy
Added support for "Trend" and "Local" radiostations (without "now playing" info)
(5.64 KiB) Downloaded 3494 times
serviio-online-backup_2020-11.sob
My list (Serviio v1.10.1) of radiostations from TuneIn (sort by categories + searchquery by categorie "Electro")
(16.12 KiB) Downloaded 3488 times
bolzass
Post Sun Dec 06, 2020 5:36 pm
Re: Tune In radio
Great job TheDoctor, thanks! (also your list of radiostations :D )
TheDoctor
Post Sat Feb 06, 2021 2:37 pm
Re: Tune In radio
Update the plugin:
TuneIn.groovy
with "now playing" info
(7.67 KiB) Downloaded 3502 times
TuneIn.groovy
(7.59 KiB) Downloaded 3450 times
Miro1001
Post Wed Nov 17, 2021 9:25 am
Re: Tune In radio
Hello, it seems to me, that the latest TuneIn plugin, posted by The Doctor, stopped working on my Win and Mac systems with Serviio v. 2.1. :o
Firoj
Post Tue Nov 30, 2021 2:32 pm
Re: Tune In radio
Having alot of fun with this new feature..
Just found that a search by zip code results in stations closeby
https://snaptube.cam/ gives stations in the Southern VT area..
wonder if you can do compound searches ..
Nice job !
Previous
Return to Available plugins
