Twitch.tv/Justin.tv
commandercool
Post Mon Nov 15, 2021 7:55 pm
Re: Twitch.tv/Justin.tv
I don't think you did anything wrong. I fact - I believe twitch API was changed once again, and now a call that fetches thumbnail fails. I've created an issue that the plugin developer could check hopefully: https://github.com/bogenpirat/serviio-plugins/issues/6 .
For now, as a workaround, you can try commenting out the thumbnail functionality. This way it works for me.
In twitch.groovy just comment out (or delete) lines 207-212 and line 225.
Or just use the file attached where it's done already.
twitch.groovy
twitch plugin with thumbnails commented out
(10.15 KiB) Downloaded 3004 times
wwenigma
Post Fri Jul 14, 2023 11:40 pm
Just tried now, plugin not working for me - anyone still use that? (tried with stock ffmpeg becouse patched one not available). First i got http401 error in logs then timeout errors.
BTW that stream url extraction tool working if that help: https://pwn.sh/tools/getstream.html / https://github.com/streamlink/streamlink
Previous
Return to Available plugins
