Zenga TV
xs2inattar
Post Tue Aug 28, 2012 1:49 am
Zenga TV
Desi streams from Zenga TV - http://www.zengatv.com/
version-1: August 27, 2011
Initial Release - Added support for live channel streams
Urls to add as video webresource
1. Live Channels: http://www.zengatv.com/home.zenga
Please test this out and let me know if it works for you.
TO-DO: Support for non-live (recorded) stuff.
ZengaTV.groovy
V1: August 27, 2012 - Initial Release - Support for Live Channels
(10.14 KiB) Downloaded 1143 times
suduko
Post Thu Aug 30, 2012 11:55 pm
Re: Zenga TV
thanks for the plugin.
I have tested and it works fine, just that the icons are not displayed. Let me check the quality of channels as well and I will update here.
suduko
Post Sat Sep 01, 2012 12:23 am
Re: Zenga TV
quality is not good.......anyways, not bad to have an alternative. :D
zit1343
Post Sat Sep 01, 2012 9:03 pm
Re: Zenga TV
Why it doesn't show up on my Sony Blu Ray Player?
I have other plugin like CBS it works fine.
any suggestions I restarted the whole PC.
Return to Available plugins
