M6 Replay (France) [BROKEN]
Post Thu Aug 23, 2012 7:56 pm
Re: M6 Replay (France)
Plugin updated with rtmp server compatible with librtmp 2.4
See first post
DTigerBKK
Post Fri Sep 21, 2012 2:47 am
M6 Replay website/player updated :x Plugin does not seem to be working any more.
(Available if I can help)
Post Fri Sep 21, 2012 7:45 am
Yes, I confirm, I will check that.
Same problem with excelent french catchup tv software : http://captvty.fr/
Post Tue Sep 25, 2012 8:32 pm
M6Replay plugin updated.
ayour
Post Thu Sep 27, 2012 1:41 pm
Merci beaucoup. il marche pour moi.
J'espere qu'il y aura d'autre plugin en francais qui marche comme tou.tv.
Thanks very much. It works for me. Thanks for your effort.
DTigerBKK
Post Fri Sep 28, 2012 4:23 am
Illico wrote:M6Replay plugin updated.
Can't find a way to grab only 1 show, but except that it's working great again! Thanks!
captvty is indeed, a VERY interesting resource.
ayour
Post Fri Dec 28, 2012 12:15 pm
M6 replay and W9 replay doesn't work for me since 3 days. Someone have the same problem?
Post Fri Dec 28, 2012 12:36 pm
ayour wrote:M6 replay and W9 replay doesn't work for me since 3 days. Someone have the same problem?
No problem for me, what is the source url that you used ?
ayour
Post Fri Dec 28, 2012 2:17 pm
thinks. I fixed the problem.
petj07
Post Wed Jan 02, 2013 10:33 am
salut,
merci pour tout
ceci dit j'ai un p'tit soucis ..
j'ai bien le dossier avec les emissions inside... mais ... elle date du mois de novembre o_O et ca me le fait qu'avec M6 .... canal+ aucun souci huhuh
j'ai loupé un truc ?
Merci
hi all
i've got some trouble with M6
the folder in Serviio it's goob but all tv show last date of month o_O?
why ? i miss something?
Post Wed Jan 02, 2013 12:26 pm
its probably because the catalogue is not uptodate, I will have a look.
Post Sun Jan 06, 2013 2:37 pm
Re: M6 Replay (France) [BROKEN]
BROKEN : M6 replay catalog used by this groovy plugin (in xml format) is no longer updated. We need to update plugin to use the new catalog in json format.
Post Sat Jan 12, 2013 2:37 pm
SEE new plugin : viewtopic.php?f=20&t=8837
Previous
Return to Available plugins
