4OD (UK only) - Web Resource
turls2201
Post Wed Jun 19, 2013 12:31 pm
Re: 4OD (UK only) - Web Resource
I have merged the two versions into the Channel4od.groovy, so you can use either feed with this new file.
Am still testing but works for me in all my testing so far but drop a response if you get an issue.
Cheers Ian
PS with this version delete the PS3Channel4od.groovy from the plugins directory
Channel4od.groovy
(27.17 KiB) Downloaded 954 times
Xmantium
Post Wed Jun 19, 2013 9:11 pm
Working perfect!!
A MILLION thanks from me and wife, she missed one born in every minute! :D
@zip, this groovy is ready!
bigguy283
Post Fri Jun 21, 2013 3:14 pm
seems all my 4od channels have gone as of today 21-06-13
i have tried all your groovy downloads but either i get (empty folders) or when i try the latest groovy i dont even get the folders at all!!
any ideas
p.s i am using on lg tv but as i said i was getting for example come-dine-with-me, dates .etc etc but now the folders are empty
turls2201
Post Fri Jun 21, 2013 7:35 pm
can you run the server in debug mode and post the log file here. You say you are using the latest version just above?
Did you install the PS3 version as well?
bigguy283
Post Sat Jun 22, 2013 10:27 am
hi there! thanks for the reply
using the original "groovy"
here is what i think you are asking for:---
2013-06-22 11:16:03,243 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 62)
2013-06-22 11:16:03,248 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/terr ... -skies/4od not in cache yet, loading it
2013-06-22 11:16:03,248 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/terror-in-the-skies/4od'
2013-06-22 11:16:03,254 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 11:16:03,673 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 11:16:03,673 DEBUG [WebResourceParser] Found matching url extractor (4OD (UK only)) for resource http://www.channel4.com/programmes/terr ... -skies/4od
2013-06-22 11:16:03,674 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Starting parsing resource: http://www.channel4.com/programmes/terr ... -skies/4od
2013-06-22 11:16:03,674 DEBUG [FeedItemUrlExtractor] 4OD (UK only): testing 7200 second timeout
2013-06-22 11:16:03,674 DEBUG [FeedItemUrlExtractor] 4OD (UK only): urlCheck is ..http://www.channel4.com/programmes/terr ... -skies/4od, terror-in-the-skies, http://ps3.channel4.com/pmlsd/terror-in ... atform=ps3
2013-06-22 11:16:04,147 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Inside programmeHtml null, Returning as no Json info found - probable not on 4od for ps3
2013-06-22 11:16:04,148 WARN [WebResourceParser] Plugin returned null container
2013-06-22 11:16:04,148 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-22 11:16:04,148 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at org.serviio.library.online.OnlineLibraryManager.getEarliestItemExpiryDate(OnlineLibraryManager.java:313)
at org.serviio.library.online.OnlineLibraryManager.storeResourceExpiryDate(OnlineLibraryManager.java:358)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
2013-06-22 11:16:04,148 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 63)
2013-06-22 11:16:04,149 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/made-in-chelsea/4od not in cache yet, loading it
2013-06-22 11:16:04,149 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/made-in-chelsea/4od'
2013-06-22 11:16:04,150 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 11:16:05,430 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 11:16:05,430 DEBUG [WebResourceParser] Found matching url extractor (4OD (UK only)) for resource http://www.channel4.com/programmes/made-in-chelsea/4od
2013-06-22 11:16:05,430 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Starting parsing resource: http://www.channel4.com/programmes/made-in-chelsea/4od
2013-06-22 11:16:05,430 DEBUG [FeedItemUrlExtractor] 4OD (UK only): testing 7200 second timeout
2013-06-22 11:16:05,431 DEBUG [FeedItemUrlExtractor] 4OD (UK only): urlCheck is ..http://www.channel4.com/programmes/made-in-chelsea/4od, made-in-chelsea, http://ps3.channel4.com/pmlsd/made-in-c ... atform=ps3
2013-06-22 11:16:05,506 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Inside programmeHtml null, Returning as no Json info found - probable not on 4od for ps3
2013-06-22 11:16:05,507 WARN [WebResourceParser] Plugin returned null container
2013-06-22 11:16:05,507 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-22 11:16:05,507 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-06-22 11:16:05,508 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 64)
2013-06-22 11:16:05,510 DEBUG [OnlineLibraryManager] Resource http://ps3.channel4.com/pmlsd/big-fat-g ... atform=ps3 not in cache yet, loading it
2013-06-22 11:16:05,510 DEBUG [WebResourceParser] Parsing web resource 'http://ps3.channel4.com/pmlsd/big-fat-gypsy-weddings.json?platform=ps3'
2013-06-22 11:16:05,511 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 11:16:05,590 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 11:16:05,592 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://ps3.channel4.com/pmlsd/big-fat-g ... atform=ps3. Message: No plugin for web resource http://ps3.channel4.com/pmlsd/big-fat-g ... atform=ps3 has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
2013-06-22 11:16:05,592 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 65)
2013-06-22 11:16:05,593 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/the-inbetweeners/4od not in cache yet, loading it
2013-06-22 11:16:05,593 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/the-inbetweeners/4od'
2013-06-22 11:16:05,594 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 11:16:05,891 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 11:16:05,892 DEBUG [WebResourceParser] Found matching url extractor (4OD (UK only)) for resource http://www.channel4.com/programmes/the-inbetweeners/4od
2013-06-22 11:16:05,892 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Starting parsing resource: http://www.channel4.com/programmes/the-inbetweeners/4od
2013-06-22 11:16:05,892 DEBUG [FeedItemUrlExtractor] 4OD (UK only): testing 7200 second timeout
2013-06-22 11:16:05,892 DEBUG [FeedItemUrlExtractor] 4OD (UK only): urlCheck is ..http://www.channel4.com/programmes/the-inbetweeners/4od, the-inbetweeners, http://ps3.channel4.com/pmlsd/the-inbet ... atform=ps3
2013-06-22 11:16:05,955 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Inside programmeHtml null, Returning as no Json info found - probable not on 4od for ps3
2013-06-22 11:16:05,956 WARN [WebResourceParser] Plugin returned null container
2013-06-22 11:16:05,956 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-22 11:16:05,956 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-06-22 11:16:15,458 DEBUG [RepositoryDAOImpl] Reading all Repositories
turls2201
Post Sat Jun 22, 2013 11:18 am
Bol******
See http://ps3.channel4.com/
After all the work - time for a re-think!!!
bigguy283
Post Sat Jun 22, 2013 12:23 pm
hi again
the latest "groovy" gives me this:-
Does this mean no more 4od for me on my LGtv using serviio????
2013-06-22 12:30:07,033 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 42)
2013-06-22 12:30:07,034 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 43)
2013-06-22 12:30:07,040 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 44)
2013-06-22 12:30:07,060 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 45)
2013-06-22 12:30:07,066 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 47)
2013-06-22 12:30:07,078 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 53)
2013-06-22 12:30:07,078 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/come ... ith-me/4od not in cache yet, loading it
2013-06-22 12:30:07,078 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/come-dine-with-me/4od'
2013-06-22 12:30:07,079 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 12:30:11,247 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 12:30:11,248 DEBUG [WebResourceParser] Found matching url extractor (4OD (UK only)) for resource http://www.channel4.com/programmes/come ... ith-me/4od
2013-06-22 12:30:11,248 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Starting parsing resource: http://www.channel4.com/programmes/come ... ith-me/4od
2013-06-22 12:30:11,248 DEBUG [FeedItemUrlExtractor] 4OD (UK only): testing 7200 second timeout
2013-06-22 12:30:11,252 DEBUG [FeedItemUrlExtractor] 4OD (UK only): urlCheck is ..http://www.channel4.com/programmes/come ... ith-me/4od, come-dine-with-me, http://ps3.channel4.com/pmlsd/come-dine ... atform=ps3
2013-06-22 12:30:11,361 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Inside programmeHtml null, Returning as no Json info found - probable not on 4od for ps3
2013-06-22 12:30:11,363 WARN [WebResourceParser] Plugin returned null container
2013-06-22 12:30:11,364 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-22 12:30:11,364 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-06-22 12:30:11,364 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 55)
2013-06-22 12:30:11,370 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 56)
2013-06-22 12:30:11,371 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/dates/4od not in cache yet, loading it
2013-06-22 12:30:11,371 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/dates/4od'
2013-06-22 12:30:11,372 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 12:30:11,703 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 12:30:11,703 DEBUG [WebResourceParser] Found matching url extractor (4OD (UK only)) for resource http://www.channel4.com/programmes/dates/4od
2013-06-22 12:30:11,703 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Starting parsing resource: http://www.channel4.com/programmes/dates/4od
2013-06-22 12:30:11,703 DEBUG [FeedItemUrlExtractor] 4OD (UK only): testing 7200 second timeout
2013-06-22 12:30:11,703 DEBUG [FeedItemUrlExtractor] 4OD (UK only): urlCheck is ..http://www.channel4.com/programmes/dates/4od, dates, http://ps3.channel4.com/pmlsd/dates/4od ... atform=ps3
2013-06-22 12:30:11,793 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Inside programmeHtml null, Returning as no Json info found - probable not on 4od for ps3
2013-06-22 12:30:11,796 WARN [WebResourceParser] Plugin returned null container
2013-06-22 12:30:11,796 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-22 12:30:11,796 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-06-22 12:30:11,797 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 58)
2013-06-22 12:30:11,797 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/food-unwrapped/4od not in cache yet, loading it
2013-06-22 12:30:11,797 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/food-unwrapped/4od'
2013-06-22 12:30:11,798 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 12:30:12,138 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 12:30:12,139 DEBUG [WebResourceParser] Found matching url extractor (4OD (UK only)) for resource http://www.channel4.com/programmes/food-unwrapped/4od
2013-06-22 12:30:12,139 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Starting parsing resource: http://www.channel4.com/programmes/food-unwrapped/4od
2013-06-22 12:30:12,139 DEBUG [FeedItemUrlExtractor] 4OD (UK only): testing 7200 second timeout
2013-06-22 12:30:12,139 DEBUG [FeedItemUrlExtractor] 4OD (UK only): urlCheck is ..http://www.channel4.com/programmes/food-unwrapped/4od, food-unwrapped, http://ps3.channel4.com/pmlsd/food-unwr ... atform=ps3
2013-06-22 12:30:12,218 DEBUG [FeedItemUrlExtractor] 4OD (UK only): Inside programmeHtml null, Returning as no Json info found - probable not on 4od for ps3
2013-06-22 12:30:12,218 WARN [WebResourceParser] Plugin returned null container
2013-06-22 12:30:12,219 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-22 12:30:12,219 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-06-22 12:30:12,219 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 60)
2013-06-22 12:30:12,226 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 61)
2013-06-22 12:30:12,227 DEBUG [OnlineLibraryManager] Resource https://www.itv.com/itvplayer/Agatha-Christie's-Marple not in cache yet, loading it
2013-06-22 12:30:12,227 DEBUG [WebResourceParser] Parsing web resource 'https://www.itv.com/itvplayer/Agatha-Christie's-Marple'
2013-06-22 12:30:12,227 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-06-22 12:30:12,459 DEBUG [WebResourceParser] Unexpected error during url extractor plugin matching (EightTracks): index is out of range 0..-1 (index = 0)
2013-06-22 12:30:12,459 DEBUG [WebResourceParser] Found matching url extractor (ITVPlayer (UK only)) for resource https://www.itv.com/itvplayer/Agatha-Christie's-Marple
2013-06-22 12:30:12,459 DEBUG [FeedItemUrlExtractor] ITVPlayer (UK only): Starting parsing resource: https://www.itv.com/itvplayer/Agatha-Christie's-Marple
2013-06-22 12:30:12,706 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ITVPlayer (UK only)): https://www.itv.com/itvplayer/Agatha-Christie's-Marple
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.io.FileNotFoundException: https://www.itv.com/itvplayer/Agatha-Christie's-Marple
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.configuredInputStream(DefaultGroovyMethods.java:16692)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.newReader(DefaultGroovyMethods.java:16760)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15130)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15102)
at org.codehaus.groovy.runtime.dgm$375.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112)
at ITVPlayerExtractor.extractItems(ITVPlayer.groovy:92)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2013-06-22 12:30:12,708 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 62)
2013-06-22 12:30:12,708 DEBUG [OnlineLibraryManager] Resource http://www.channel4.com/programmes/terr ... -skies/4od not in cache yet, loading it
2013-06-22 12:30:12,708 DEBUG [WebResourceParser] Parsing web resource 'http://www.channel4.com/programmes/terror-in-the-skies/4od'
2013-06-22 12:30:12,708 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl:
turls2201
Post Sat Jun 22, 2013 2:09 pm
It will not work- Channel 4 have taken down their PS3 web site - am just searching to see if I can use other alternatives - eg android
Cheers Ian
Xmantium
Post Sat Jun 22, 2013 2:13 pm
The plugin is not working as it uses the PS3 app data which has been recently changed :(
Damn it, i was enjoying it
turls2201
Post Sat Jun 22, 2013 6:08 pm
made a breakthrough, but does anyone know about a authentication key X-C4-API-KEY?
webego
Post Sat Jun 22, 2013 11:15 pm
Just watched something on 4OD (via laptop) and saw an add about the 4OD PS3 App now available. Maybe this is why they are taking the site down?
G
AlVal
Post Sat Oct 26, 2013 3:39 pm
confirmed not working for above reasons
Previous
Return to Available plugins
