Vevo Top Videos
brunohansen
Post Sat Apr 27, 2013 7:15 pm
Vevo Top Videos
Another new beta version of Vevo Top Videos (05/12/2013)
The video search was improved and now you can choose artists' videos.
The dummy address of Web Resource is the same: http://www.vevo.com, if you only use the dummy address, the plugin will show Top Videos most viewed today from all genres. If artist parameter is present, artist's videos will be shown, otherwise, Top Videos will be shown!
--------------- ARTIST
To choose an artist, go to the vevo web page, search for the artist you want, copy the artist's name from the result URL and put it in artist parameter. (You can choose the order and the max number of results, as in Top Videos!)
Artist Example:
Artist = Maroon 5
http://www.vevo.com/watch/maroon-5/moves-like-jagger/USUV71101090?source=lucenesearch
http://www.vevo.com?artist=maroon-5&order=mostrecent&max=6
--------------- TOP VIDEOS
The params are the same used at http://www.vevo.com/videos/topvideos, go there choose the genre and the order, and copy the params from the result URL.
Params Example:
http://www.vevo.com/videos/topvideos#genre=rock&order=mostrecent
http://www.vevo.com?genre=rock&order=mostrecent
You can get differents kinds of genre from many vevo pages, so you can copy it and try it on. It is the case of http://m.vevo.com/videos.
To especify the max number of results, you can add the "max" param. For default Vevo plugin will use max defined at Serviio if unlimited it will be 100.
Max example:
http://www.vevo.com?genre=rock&order=mostrecent&max=10
To use Vevo Top Videos you must have the YouTube plugin installed: viewtopic.php?f=20&t=3276
Added 04/27/2013
Updated for 0.1.1 05/03/2013
Updated for 0.2.0 05/12/2013
VevoBeta.groovy
(11.75 KiB) Downloaded 1658 times
Xmantium
Post Sun Jul 21, 2013 3:21 pm
Re: Vevo Top Videos
This looks to be really good plugin as Vevo has so many popular Music videos - http://www.vevo.com
Since jhb50 YouTube Top 100 and Billboard Top 20 stopped working due to YouTube changes this plugin definitely has potential to be the best Music Video plugin for Serviio :)
Majority of the video were from Vevo too.
I cant seem to get it to work and the plugin developer not been on the forums for two months - help!
brunohansen
Post Wed Aug 21, 2013 2:18 am
Re: Vevo Top Videos
Xmantium wrote:This looks to be really good plugin as Vevo has so many popular Music videos - http://www.vevo.com
Hi, Xmantium.
It works with preferred online content quality HIGH and LOW!
Seems to be a problem in Youtube plugin, . I'll check it!
pistolpete
Post Wed Aug 21, 2013 10:07 am
Re: Vevo Top Videos
The Vevo Plugin is working fine for me too :)
All i did to get it to work was copy the vevobeta.groovy to the serviio/plugins directory and then in the serviio console under the library/ online sources i then added it as a web resource with the url as http://www.vevo.com
It works a treat and i love it... :)
All HD videos too and look great
Post Wed Aug 21, 2013 5:02 pm
Re: Vevo Top Videos
I works again because YouTube stopped encoding signatures last night. This may only be temporary.
Post Wed Aug 21, 2013 6:02 pm
Re: Vevo Top Videos
I had to add this to the start of the groovy to prevent the 30 second timeout. I now works fine.
int getExtractItemsTimeout() {
//# increase timeout from 30 second default
return 60
pistolpete
Post Tue Aug 27, 2013 11:56 pm
Re: Vevo Top Videos
@jbh50,
are you able to confirm these signatures have been re activated ?? im now getting all the videos show up on my tv , well what videos are available but now my tv is saying it doesn't have the avaible codec to play them ? any thoughts from your end ?
cheers
Pete
Post Wed Aug 28, 2013 12:14 am
Re: Vevo Top Videos
Yes sigs have been reactivated.
xerano
Post Sun Oct 19, 2014 8:47 am
Re: Vevo Top Videos
Vevo Plugin is not working for me any solution?
i would like get VEVO.TV an Top Videos Working on Serviio :/
Return to Available plugins
