Tv3Play (Sweden)
GamePat
Post Wed May 08, 2013 6:31 am
Re: Tv3Play (Sweden)
Today I tried this plugin to see if it works.
I registered to Tv3play and created a playlist and added it to Serviio.
To my surprise it turned up on my blu-ray player and I could immediately watch it.
BUT after 48 seconds (tried with 2 list entries) the picture freezes, but the sound continuous.
I also got this on 1 program on SVTPlay, but it froze after 7-8 minutes. I have been able to see full program on SVTPlay through serviio.
On SVTPlay I got a message (in swedish) that could be translated into: "not compatible video data" or "video data could not be transcoded".
Probably same with TV3Play. I find it weird that after some time the video data cannot be transcoded and viewed, I mean it's not that it suddenly changes???
Can someone help me?
My blu-ray player: Samsung BD-D8200N (with latest firmware 1014), using latest Serviio 1.2.1
Update: TV3Play seems to work now, just tested and it plays beyond the 48 seconds, how far I will test tomorrow (hopefully all the way through). My Blu-Ray player has update firmware, but that has nothing to do with serviio.
MartinGhuusfeldt
Post Thu Jan 23, 2014 5:31 pm
Maybe a stupid question but somehow I cant see the folders at all..
I got others that works fine like YouTube channels but this I cant get to work and I suspect it is in the Presentation
since I like to disabled all other I don't need and to be honest I don't remember standard setting anybody can assist I truly appreciate it?
It would solve for me many problems..
MartinGhuusfeldt
Post Thu Jan 23, 2014 5:46 pm
dualc wrote:
Janne wrote:Well, same here...
I can't get the TV3 or TV6 plugin to work, I get empty folder on the TV and the log is full this, even when I'm down to one single TV3 feed:
2011-10-06 21:46:16,088 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/sweden/tv3/AdamLive/Season1/Program/adamlive_122_111004.mp4. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
   ... 1 more
Making 5 full log files per hour... :?
Any ideas?
(BTW. big thanks for the SVT plugin, works wonderfully and I use it almost every day! :D)
Cool u have a working SVT plugin, .. i dont. :) cant see anything.. :/
At least you see a folder, I don't :-(
MartinGhuusfeldt
Post Sat Jan 25, 2014 9:03 am
tv3 not worth the effort lol...
ottomatic
Post Tue Oct 28, 2014 10:03 pm
Hi everyone.
Are people still using this plugin? It seems that there are no longer any RSS feeds offered at the tv3play.se site.
Also, the streaming protocol seems to have moved from rtmp to hls and hds.
So, I am considering writing a new plugin for tv3play.se / tv6play.se / tv8play.se / tv10play.se.
This would work similarly to the svtplay.se plugin; it would be a WebResource type plugin, scraping the web pages and parsing some JSON in order to provide show links.
Now: If you have any ideas on how you would want such a plugin to use, please comment in this thread. Like, if you click around on the tv3play site, what sections / shows would you want to stuff into serviio as a feed, and what items would you want to get as a result? Are you interested in the shows only, or also the (short) clips?
My primary purpose would be to watch The Blacklist, so I would register the feed Url:
http://www.tv3play.se/program/blacklist
And then I would expect all the available episodes to be listed in reverse chronological order.
Please provide your input!
/ O
ottomatic
Post Thu Nov 13, 2014 12:35 am
Hi again,
I have now implemented a plugin which has unified support for tv3play.se, tv6play.se, tv8play.se, tv10play.se and similar sites run by MTG in other countries as well.
Head over to:
viewtopic.php?f=20&t=17873
Regards
/ O
Previous
Return to Available plugins
