AceStream Plugin
georgian
Post Sun Dec 29, 2013 8:26 am
AceStream Plugin
hi
as u all probably know acestream has taken over Sopcast
i tried many ways integrating acestream with serviio (tried same method as sopcast,enterin 127.0.0 IP adresses etc) but it still didnt work
some1 plz b kind enuff to find a way/method to integrate it with serviio
thx
Post Sun Dec 29, 2013 7:53 pm
Re: AceStream Plugin
mod..please move to plugin requests.
Xmantium
Post Sun Dec 29, 2013 7:54 pm
SopCast is still available, Im not aware about SopCast been taken over by AceStream, theres less streams compared to last year.
Anyway. This forum topic is for ready made groovy plugins
Please Moderators move this to plugin requests
georgian
Post Sun Dec 29, 2013 8:31 pm
:) what i meant was acestream is becoming more popular cos sopcast keep banning soccer streams
anyways if somebody could come up with a solution u b doing a lot of us soccerfans big faveours
Xmantium
Post Sun Dec 29, 2013 11:11 pm
There is a tested way of making AceStream work for Serviio found here - viewtopic.php?f=4&t=14751#p84522
but it seems this method got broken with v1.4...
georgian
Post Mon Dec 30, 2013 1:53 pm
hopefully some1 will fix this
georgian
Post Sat Jan 04, 2014 7:25 pm
any1? :roll: :roll: :roll:
Post Sun Jan 05, 2014 3:45 am
This statement is incorrect. The method works as described with 1.4. I am streaming viasat basketball right now. Be sure to use 8902/tv.asf
georgian
Post Sun Jan 05, 2014 9:10 am
lol i seemed to be cursed with using serviio
1. i couldnt get the plugins to work
2. acestream has been a nightmare,couldnt get that to work either
maybe its my windows? im on win7 64bit
mollser
Post Fri Jan 10, 2014 12:05 pm
I have Acestream working beautifully with Serviio
What I do find however is that the IP4 address for my PC often changes when I reboot the computer - this will then involve editing the IP address used in the Acestream 'source' in the online library so it matches the newly allocated IP address.
Then refresh the stream and flawless HD streaming to my tele.
Thank you Serviio!!
narf
Post Wed Jan 22, 2014 12:25 am
I also had this issue with 1.4 I had to revert back to 1.3. I tried all my usual trouble shooting and nothing could get the stream to appear (restarting the service, re-checking the url and got the green check, refreshed library, nothing worked.). I reinstalled 1.3 and it popped right up.
Return to Available plugins
