SC2Casts
AMoo-Miki
Post Sun Sep 25, 2011 8:27 pm
SC2Casts
Open the console of your serviio 0.6 and go to the library -> online sources. Hit add and paste this address in there: http://barahmand.com/serviio/sc2casts.php
The url above is to fix the BOM at the beginning of the rss feed, which Java doesn't like.
Probably the newer versions of serviio will have a mechanism to skip the BOM, letting you use the original SC2 feed which is http://sc2casts.com/rss/rss.php.
SC2Casts.groovy
SC2Casts
(5.89 KiB) Downloaded 1116 times
sampath.mamilapo
Post Fri Oct 14, 2011 2:56 am
Re: SC2Casts
http://barahmand.com/serviio/sc2casts.php is dead. Will you update the plugin?
Return to Available plugins
