Israel channel 10
peter1212
Post Fri Jan 20, 2012 9:01 am
Israel channel 10
Maybe I'm not writing on the right topic but can someone convert the resource of channel 10
<object width="448" height="366"><param name="movie" value="http://f.nanafiles.co.il/Common/Flash/Nana10Preloader.swf"/><param name="allowfullscreen" value="true" /><param name="flashvars" value="VideoID=88436&ArticleID=0&SectionID=0&CategoryID=210155&HiroRatio=0"/><embed src="http://f.nanafiles.co.il/Common/Flash/Nana10Preloader.swf" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="448" height="366" flashvars="VideoID=88436&ArticleID=0&SectionID=0&CategoryID=210155&HiroRatio=0"/></object>
to a string i can input to serviio?
peter1212
Post Sat Jan 21, 2012 7:53 pm
Re: Israel channel 10
I managed to isolate it
http://10tv.nana10.co.il/Video/?VideoID ... 48&sid=169
do I need a plugin or can I insert it directly?
peter1212
Post Wed Jan 25, 2012 8:48 pm
I used url snooper
rtmpt://s0mfl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120125203548&ts=0&cu=45090D24-C95D-4813-96B4-2E5A768DB00F&cuud=pid48&cuud=pid48;rtmpt://sv8fl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120125203548&ts=0&cu=45090D24-C95D-4813-96B4-2E5A768DB00F&cuud=pid48&cuud=pid48;rtmpt://sv5fl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120125203548&ts=0&cu=45090D24-C95D-4813-96B4-2E5A768DB00F&cuud=pid48&cuud=pid48;rtmpt://sv9fl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120125203548&ts=0&cu=45090D24-C95D-4813-96B4-2E5A768DB00F&cuud=
how to play rtmpt?
Post Thu Jan 26, 2012 8:16 am
peter1212 wrote:do I need a plugin or can I insert it directly?
Yes you need a plugin.
http://wiki.serviio.org/doku.php?id=servio_plugins
http://wiki.serviio.org/doku.php?id=ser ... _explained
Return to Plugin requests
