Ustream Plugin for Synology NAS
prmadmax
Post Fri Mar 01, 2013 3:44 am
Looking for someone to make the Ustream plugin work with Synology NAS.
Plugin topic: viewtopic.php?f=20&t=6877
Plugin logic: https://github.com/piscui/ustream-to-ffmpeg
I messaged the developer but since they don't seem to be around anymore I was hoping someone else could pick this up?
What I know so far:
While using a Synology NAs and entering Ustrealm URLs while using this plugin do not appear. This does not appear to be an issue with serviio but rather the plugin.
If I use http://piscui.webear.net/ustream.php to convert the URL and then enter that it works flawlessly.
Few comments in the BETA forum regarding this here: viewtopic.php?f=8&t=9267#p64226
I have tested this on my computer and the stream shows up as it should... so this is something limited to the Synology NAS.
Regards, MadMax
Serviio Beta Tester
Samsung Series 6 UE32H6400 (3D Full HD Smart TV)
Synology DS1512+ / 3GB Ram / 5x 3TB WD Red Edition HDDs with 5.2 firmware running Patters Serviio package for Synology NAS
patters
Post Fri Mar 01, 2013 9:00 pm
Re: Ustream Plugin for Synology NAS
Are you using the genuine Serviio Console running on a PC to manage the NAS, or a 3rd party Web UI?
prmadmax
Post Sat Mar 02, 2013 1:34 am
patters wrote:Are you using the genuine Serviio Console running on a PC to manage the NAS, or a 3rd party Web UI?
Yes, Using the remote serviio console.
Regards, MadMax
Serviio Beta Tester
Return to Plugin requests
