Australian TV Plugins
Aardvogel
Post Fri Oct 14, 2011 7:15 am
Would really like to see plugins to support Australian TV Channels
ABC IVIEW http://www.abc.net.au/iview/ or on RSS Feed http://www.abc.net.au/tv/iview/feeds.htm
Channel 7 http://au.tv.yahoo.com/plus7/
Channel 9 http://channelnine.ninemsn.com.au/video
Channel 10 http://ten.com.au/watch-tv-episodes-online.htm
SBS http://www.sbs.com.au/ondemand/
Thanks for your help
ttguy
Post Tue Sep 04, 2012 3:18 pm
Re: Australian TV Plugins
Aardvogel wrote:Would really like to see plugins to support Australian TV Channels
Yep. Done the iView one see here
Might try and write an SBS one next. Since my gold Xbox membership expired I can't see SBS on demand on my Xbox.
linux/Humax HDR-3000T
Aardvogel
Post Thu Sep 06, 2012 9:14 am
Many thanks for doing this, I will give it a try over the weekend
thechocobn
Post Wed Sep 12, 2012 5:40 am
Hi There,
I tested iView for the first time yesterday, it works really well ! Well done!
What are the prospects of having one for SBS? That would be really good considering all the good movies available.
Cheers,
Steph.
ttguy
Post Sun Sep 23, 2012 1:53 pm
thechocobn wrote:Hi There,
Cheers,
Steph.
Here it is !
chorf2001
Post Thu Mar 21, 2013 12:46 am
Hi Guys,
I'm rather new at this and need some advice as to where I'm going wrong. I have been having problems getting any online sources to work.
For example I tried the ABC iView groovy file, placing it in my C:\Program Files\Serviio\plugins file. I then created an online source with the following details:
"Source Type: Web Resource
Source URL: http://feed.theplatform.com/f/dYtmxB/fe ... ?form=json
Display Name: ABC Recient"
Looking at the log it would seem that the groovy is loading
2013-03-21 10:33:47,484 INFO [PluginCompilerThread] Added Feed plugin ABC iView (Australia only) (ABCiView.groovy), version: 1
But it also seems that the web the resource is unable to find it.
"2013-03-21 11:16:36,234 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://tviview.abc.net.au/iview/rss/recent.xml. Message: No plugin for web resource http://tviview.abc.net.au/iview/rss/recent.xml has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:96)"
I am running Serviio 1.2 (but had the same problem with the older version) on Windows XP, and streaming to a Denon DBP1611UD via cable. I am able to stream local content without issue. I am using a Denon profile with Transcoding enabled.
When looking at the online folder via the Denon I sometimes see subfolders that match the online sources added, however, the are always empty.
I have tried different variations ie: Web resource / Online RSS Feed (the iview is meant to be set as a web resource I believe) with no luck.
Am I doing something wrong? Any feedback would be appreciated.
Thanks,
Chrof2001.
chorf2001
Post Thu Mar 21, 2013 1:24 am
Sorry,
That Web resource URL mentioned above should have been http://tviview.abc.net.au/iview/rss/recent.xml
not http://feed.theplatform.com/f/dYtmxB/fe ... ?form=json
Cheers,
Chorf2001 :o
Return to Plugin requests
