Assign rtmp parameters of web resource realtime
rrajnai
Post Tue May 07, 2013 2:53 pm
I am not sure, whether this is the correct forum, but I did not find a solution to my problem anywhere either.
There are lot of streaming sites, which assign session IDs as parameters in their rtmp assignments dynamically. (For example filmon is an example of it.)
I have prepared a script, which by analysing the site content, establishes this and other parameters, but I do not know how to pass it to Serviio, before the streaming would commence.
I was thinking, that I could make an RSS file (and save it as a Serviio configuration), which in main effect would call my script. The script would then establish the current rtmp and swf parameters (and perhaps server addresses as well) and could pass them back to Serviio in xml format.
Does anybody know a way to do it? (Perhaps a plugin would be a solution to it, but unfortunately I do not know groovy.)
slyguy42o
Post Tue May 07, 2013 7:16 pm
Re: Assign rtmp parameters of web resource realtime
it sounds like a plugin would be needed but I am not a coder so I can't say for sure.
Post Tue May 07, 2013 7:48 pm
That's what a plugin is for, and groovy is trivial. See the plug-in guide. http://www.serviio.org/index.php?option ... icle&id=42
Return to Plugin requests
