Ustream plugin needs updating / remaking
prmadmax
Post Wed Dec 11, 2013 12:04 am
Hey,
It looks like some streams on ustream are broadcast slightly different to what they used to be.
For example this stream does not seem to work any more and it is certainly live:
http://www.ustream.tv/nasahdtv
Original Plugin topic: viewtopic.php?f=20&t=6877
Plugin logic: https://github.com/piscui/ustream-to-ffmpeg
I have the php file over here: http://madmax.phantomrebels.com/Documen ... stream.php
From what I can tell the author xs2inattar of the plugin is no longer around (and has not been since Dec 2012), I am asking if someone else can take up developing the ustream plugin using the logic from the github repo?
Regards, MadMax
Serviio Beta Tester
Samsung Series 6 UE32H6400 (3D Full HD Smart TV)
Synology DS1512+ / 3GB Ram / 5x 3TB WD Red Edition HDDs with 5.2 firmware running Patters Serviio package for Synology NAS
JamesHB
Post Mon Mar 10, 2014 11:24 pm
Re: Ustream plugin needs updating / remaking
Any new developments on this plugin?
Return to Plugin requests
