Develop a plugin for channel 10
peter1212
Post Fri Jan 27, 2012 9:53 am
Hi all,
I'm trying to develop a plugin for http://10tv.nana10.co.il/Video/?VideoID=88436&TypeID=5&CategoryID=210155&pid=48&sid=169
I'm following the http://stream-recorder.com/forum/tutorial-simply-use-rtmpsrv-and-example-t6325.html?p=18142#post18142 tutorial
1) using urlsnooper i extracted :
http://f.nanafiles.co.il/Common/Flash/Nana10Preloader.swf?Version=20120122&VideoID=88436&ArticleID=682100&AutoPlay=1&EnableEmbed=1
http://f.nanafiles.co.il/Common/Flash/Nana10Player.swf?Version=20120122
rtmpt://s0mfl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120127093951&ts=0&cu=7ACEBD7E-FF84-4DC6-BE13-D0913AA1EC0B&cuud=pid48&cuud=pid48;rtmpt://sv8fl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120127093951&ts=0&cu=7ACEBD7E-FF84-4DC6-BE13-D0913AA1EC0B&cuud=pid48&cuud=pid48;rtmpt://sv5fl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120127093951&ts=0&cu=7ACEBD7E-FF84-4DC6-BE13-D0913AA1EC0B&cuud=pid48&cuud=pid48;rtmpt://sv9fl.castup.net:1935/993860018-123.flv?ct=IL&rg=NV&aid=386&tkn=20120127093951&ts=0&cu=7ACEBD7E-FF84-4DC6-BE13-D0913AA1EC0B&cuud=
rtmp://s0ffl.castup.net:1935/993860018-123.flv/_definst_/_definst_
now what should be the host:
1) s0ffl.castup.net
2) s0ffl.castup.net:1935
3) sv8fl.castup.net
4) sv8fl.castup.net:1935
5) s0mfl.castup.net
6) s0mfl.castup.net:1935
7) f.nanafiles.co.il
8) 10tv.nana10.co.il
I changed the host file to:
127.0.0.1 s0ffl.castup.net:1935
ran the batch file rtmpsrv.bat
all i see in the command prompt window is:
RTMP Server 2.4 git-6230845 2011-9-25
(c) 2010 Andrej Stepanchuk, Howard Chu; license: GPL
Streaming on rtmp://0.0.0.0:1935
The text file is empty.
can someone tell me what to write as the host? and why the text file is empty?
Post Fri Jan 27, 2012 12:57 pm
Re: Develop a plugin for channel 10
you should now try to open the web page again and the flash player should talk to your rtmpserv rather than the real server.
peter1212
Post Fri Jan 27, 2012 4:02 pm
I did it but i receive:
txt
ERROR: Handshake failed
Closing connection... done!
(I entered all the hosts to the host file)
Any suggestion ?
peter1212
Post Sat Jan 28, 2012 7:14 pm
while running RTMP Server with host block the movie (stream) still works.
Need some help here !
Post Sun Jan 29, 2012 11:06 am
Dont enter the port number into hosts file.
peter1212
Post Sun Feb 05, 2012 7:49 pm
O.k.
here is the feed
if some one finds the HD parameter write it down
Return to Plugin development
