Confused about Groovy
Post Sun Aug 19, 2012 3:47 am
I wanted to test a groovy file as listed on the Serviio Wiki http://wiki.serviio.org/doku.php?id=servio_plugins. Everything seems to be pointing to Groovy.exe being installed with Serviio. However, I searched the hard drive and found no such file. I did a web search and found where to download Groovy, which I have done and installed. My test script still fails, but I think it has something to do with 32 vs 64 bit Java, and I'm not going to bother troubleshooting it right now.
However, I am wondering if Groovy was supposed to be installed along with Serviio, or is Groovy embedded within one of the other files included with Serviio? If it's embedded, how is this test function supposed to work? If it is supposed to be installed along with Serviio, could this explain the problems I am having attempting to use online content on some of my viewing devices?
I am only having success with online content via my 2011 Panasonic Plasma TV (ST50 series). My Panasonic BLuRay player (BDP110) won't play anything and won't even let me scroll the available folders. My Sony SNP-N200 sees all the folders, but they are all empty of any content.
Post Sun Aug 19, 2012 7:05 am
Re: Confused about Groovy
Are you trying to use someone's plugin, or are you looking to develop your own. If it is the first, ask in the plugin's thread as the developer should be able to help you.
Groovy is distributed as a jar in the libs folder IIRC.
Return to Plugin development
