Apache Directory Listing WebResourceUrlExtractor
didu
Post Fri Aug 09, 2013 10:22 pm
Hi everyone !
I just discovered serviio and I would like to say first, Thank all the developper ! it is a amazing work !
Otherwise I have some question about plugin development ,
I have create a simple plugin of type WebResourceUrlExtractor.
This plugin is able to extract Movie file from a apache Directory Listing.
Everything work well, I can stream the movie without problem (The name of the file are just horrible because of html caractere but I will fix it).
Now I would like to know if it is possible to set the name/url of the subtitle for each file ? (The subtitle have the same name as the movie and in the same folder)
Thank you :)
Post Fri Aug 09, 2013 10:24 pm
Re: Apache Directory Listing WebResourceUrlExtractor
No, plugins don't support subtitles yet.
https://bitbucket.org/xnejp03/serviio/i ... ne-plugins
didu
Post Fri Aug 09, 2013 10:34 pm
Oh ok I see, is it possible to help to implement this feature ?
Return to Plugin development
