API for generating feeds?
ottomatic
Post Sat Oct 12, 2013 10:31 pm
I was wondering if there is any API for automatically creating feed definitions?
Like, if the standard user of my plugin usually adds 26 feeds, one for each letter of the alphabet, it would be nice to provide a script to do
this.
Regards
/ O
Post Sun Oct 13, 2013 12:30 am
Re: API for generating feeds?
The easiest would be to export all of these (once added to the library) via the console as a .sob file and share it with your plugin.
Or you can just add the ServiioLinks on the plugin page too, separately.
Post Sun Oct 13, 2013 12:51 am
you could also add your plugin to my site and then people could use one of the third party serviio apps to add the feeds. This way the feeds could be updated easier.
Return to Plugin development
