[Closed-ffmpeg problem]mov file from plugin won't display
Post Sun Dec 18, 2011 4:30 am
I have a .mov file passed back from a groovy that will not add to the menu. All the other files are .mp4 and display correctly. Running in test mode for that item the groovy returns:
Result: ContentURLContainer [fileType=VIDEO, contentUrl=http://funkwarehouse.com
/jcpods/john_cleese_podcast_28.mov, live=false, expiresImmediately=false, ]
When adding the feed that uses the groovy the log shows the file is accepted, just like all the other items:
2011-12-17 17:10:37,626 DEBUG [FeedItemUrlExtractor] Cleeseblog: Starting extraction of url for item: John Cleese Podcast #28: The Night Before Christmas
2011-12-17 17:10:38,518 DEBUG [FeedItemUrlExtractor] Cleeseblog: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov, live=false, expiresImmediately=false, ]
2011-12-17 17:10:38,518 DEBUG [FeedParser] Added feed item 8: 'John Cleese Podcast #28: The Night Before Christmas' (http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov)
but it is then rejected as "unknown video file type" and is not added to the menu.
2011-12-17 17:10:43,613 DEBUG [FeedUpdaterThread] Retrieving file size from the URL connection
2011-12-17 17:10:43,750 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'John Cleese Podcast #28: The Night Before Christmas'
2011-12-17 17:11:43,791 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:261)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:200)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:99)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:321)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:71)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:243)
   ... 2 more
ffmpeg -i shows as follows and the downloaded file plays correctly in serviio as a native video/mp4.
C:\Users\John>ffmpeg -i "http://funkwarehouse.com/jcpods/john_cleese_podcast_28.
mov" D:\cleese.mov
ffmpeg version N-33591-gf884ef0, Copyright (c) 2000-2011 the FFmpeg developers
  built on Oct 13 2011 02:23:02 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 21. 0 / 51. 21. 0
  libavcodec   53. 20. 1 / 53. 20. 1
  libavformat  53. 15. 0 / 53. 15. 0
  libavfilter   2. 43. 6 /  2. 43. 6
  libpostproc  51.  2. 0 / 51.  2. 0
Seems stream 1 codec frame rate differs from container frame rate: 5994.00 (5994
/1) -> 29.97 (2997/100)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://funkwarehouse.com/jcpods/john_cl
eese_podcast_28.mov':
    major_brand     : qt
    minor_version   : 537199360
    compatible_brands: qt
    creation_time   : 2007-12-21 17:54:44
  Duration: 00:04:16.25, start: 0.000000, bitrate: 1045 kb/s
    Stream #0:0(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, s16, 191
 kb/s
      creation_time   : 2007-12-21 17:58:52
    Stream #0:1(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 320x240,
850 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
[buffer @ 03B706A0] w:320 h:240 pixfmt:yuv420p tb:1/1000000 sar:0/1 sws_param:
[libx264 @ 047CC520] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE
4.2
[libx264 @ 047CC520] profile High, level 1.3
[libx264 @ 047CC520] 264 - core 118 r2085 8a62835 - H.264/MPEG-4 AVC codec - Cop
yleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deb
lock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 m
e_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chro
ma_qp_offset=-2 threads=12 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_
compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 w
eightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh
=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4
 ip_ratio=1.40 aq=1:1.00
strptime() unavailable on this system, cannot convert the date string.
Output #0, mov, to 'D:\cleese.mov':
    major_brand     : qt
    encoder         : Lavf53.15.0
    Stream #0:0(eng): Video: h264 (avc1 / 0x31637661), yuv420p, 320x240, q=-1--1
, 2997 tbn, 29.97 tbc
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, s16, 128
 kb/s
Stream mapping:
  Stream #0.1 -> #0.0 (h264 -> libx264)
  Stream #0.0 -> #0.1 (aac -> libvo_aacenc)
frame=   42 fps=  0 q=0.0 size=       0kB time=00:00:00.00 bitrate=   0.0kbits/s
frame=   65 fps= 64 q=29.0 size=       8kB time=00:00:00.23 bitrate= 295.1kbits/
frame=   86 fps= 56 q=29.0 size=      40kB time=00:00:00.93 bitrate= 349.7kbits/
frame= 7456 fps= 63 q=29.0 size=    7403kB time=00:04:06.84 bitrate= 245.7kbits/
frame= 7492 fps= 63 q=29.0 size=    7432kB time=00:04:08.04 bitrate= 245.4kbits/
frame= 7591 fps= 63 q=29.0 size=    7528kB time=00:04:11.35 bitrate= 245.3kbits/
frame= 7678 fps= 64 q=-1.0 Lsize=    7814kB time=00:04:16.12 bitrate= 249.9kbits
/s
video:3610kB audio:4004kB global headers:0kB muxing overhead 2.627229%
[libx264 @ 047CC520] frame I:36    Avg QP:18.07  size: 11496
[libx264 @ 047CC520] frame P:3042  Avg QP:24.62  size:   823
[libx264 @ 047CC520] frame B:4600  Avg QP:29.20  size:   170
[libx264 @ 047CC520] consecutive B-frames: 16.4%  9.4%  5.4% 68.9%
[libx264 @ 047CC520] mb I  I16..4: 34.5% 19.8% 45.7%
[libx264 @ 047CC520] mb P  I16..4:  2.5%  1.8%  0.8%  P16..4: 16.6%  5.9%  3.7%
 0.0%  0.0%    skip:68.7%
[libx264 @ 047CC520] mb B  I16..4:  0.3%  0.2%  0.1%  B16..8:  7.5%  1.5%  0.3%
 direct: 0.8%  skip:89.3%  L0:47.4% L1:47.2% BI: 5.4%
[libx264 @ 047CC520] 8x8 transform intra:32.4% inter:54.8%
[libx264 @ 047CC520] coded y,uvDC,uvAC intra: 35.8% 53.8% 30.6% inter: 4.8% 7.5%
 2.3%
[libx264 @ 047CC520] i16 v,h,dc,p: 43% 26% 11% 20%
[libx264 @ 047CC520] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 20% 32%  4%  6%  6%  6%
 5%  5%
[libx264 @ 047CC520] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 20% 23%  6%  7%  6%  7%
 5%  6%
[libx264 @ 047CC520] i8c dc,h,v,p: 56% 19% 17%  8%
[libx264 @ 047CC520] Weighted P-Frames: Y:10.6% UV:7.1%
[libx264 @ 047CC520] ref P L0: 64.6% 12.8% 14.4%  6.5%  1.8%
[libx264 @ 047CC520] ref B L0: 81.2% 15.7%  3.1%
[libx264 @ 047CC520] ref B L1: 91.2%  8.8%
[libx264 @ 047CC520] kb/s:115.41
C:\Users\John>
What's my problem?
Post Sun Dec 18, 2011 1:50 pm
Re: mov file from plugin won't display
not sure, my local test works. You could enable TRACE logging (instead of DEBUG) and you should see what output FFmpeg actually produces.
Post Sun Dec 18, 2011 2:26 pm
Tried
<category name="org.serviio.library.online">
      <priority value="TRACE"/>
</category>
but still only getting DEBUG output after restart.
Post Sun Dec 18, 2011 2:55 pm
Used
<category name="org.serviio">
</category>
And got this but no ffmpeg results show.
2011-12-18 09:36:51,591 DEBUG [FeedUpdaterThread] Retrieving file size from the URL connection
2011-12-18 09:36:51,674 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'John Cleese Podcast #28: The Night Before Christmas'
2011-12-18 09:36:51,676 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov
2011-12-18 09:36:51,676 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov
2011-12-18 09:36:51,677 TRACE [ProcessExecutor] Env variables: {ProgramData=C:\ProgramData, USERPROFILE=C:\windows\system32\config\systemprofile, PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC, DEVKITPPC=/c/devkitPro/devkitPPC, JAVA_HOME=C:\Program Files (x86)\Java\jdk1.6.0_10, ProgramFiles(x86)=C:\Program Files (x86), GROOVY_HOME=C:\Groovy\groovy-1.8.3, SystemDrive=C:, TEMP=C:\windows\TEMP, ProgramFiles=C:\Program Files, DEVKITPRO=/c/devkitPro, Path=C:\Program Files (x86)\Common Files\ArcSoft\Bin;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\Bitvise Tunnelier;C:\Program Files (x86)\Universal Extractor;C:\Program Files (x86)\Universal Extractor\bin;C:\Program Files (x86)\MKVtoolnix;C:\Program Files (x86)\TortoiseSVN\bin;C:\Program Files\TortoiseSVN\bin;C:\Program Files (x86)\Calibre2\;C:\Program Files (x86)\MKVtoolnix3.4;;c:\program files\java\jre6\bin, HOMEDRIVE=C:, JENV_2=http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov, PROCESSOR_REVISION=1e05, JENV_1=-i, USERDOMAIN=WORKGROUP, ALLUSERSPROFILE=C:\ProgramData, ProgramW6432=C:\Program Files, PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 30 Stepping 5, GenuineIntel, TMP=C:\windows\TEMP, PROCESSOR_ARCHITECTURE=AMD64, CLASSPATH=C:\Program Files (x86)\Serviio\lib\serviio.jar, CommonProgramFiles=C:\Program Files\Common Files, OS=Windows_NT, FP_NO_HOST_CHECK=NO, HOMEPATH=\windows\TEMP\, PROCESSOR_LEVEL=6, CommonProgramW6432=C:\Program Files\Common Files, LOCALAPPDATA=C:\windows\system32\config\systemprofile\AppData\Local, COMPUTERNAME=W7-PC, SystemRoot=C:\windows, windir=C:\windows, NUMBER_OF_PROCESSORS=8, PSModulePath=C:\windows\system32\WindowsPowerShell\v1.0\Modules\, PUBLIC=C:\Users\Public, USERNAME=W7-PC$, CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files, ComSpec=C:\windows\system32\cmd.exe, APPDATA=C:\windows\system32\config\systemprofile\AppData\Roaming}
2011-12-18 09:36:52,311 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2011-12-18 09:36:52,695 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:22
2011-12-18 09:37:12,159 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2011-12-18 09:37:12,160 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2011-12-18 09:37:51,681 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-18,1,main]
2011-12-18 09:37:51,690 DEBUG [ProcessUtils] Killing the Windows process: 13028
2011-12-18 09:37:51,721 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov. It might not play.
   ... 2 more
2011-12-18 09:37:51,723 DEBUG [TechnicalMetadataCacheDecorator] Found technical metadata for online item 'http://funkwarehouse.com/jcpods/john_cleese_podcast_27.mp4' in the cache (online_technical_metadata), returning it
Post Sun Dec 18, 2011 3:33 pm
it times out after 1 minute. how long does it take to get results if your run ffmpeg -i on that URL ? (without the output file)
Post Sun Dec 18, 2011 3:37 pm
Response on ffmpeg -i is immediate, but yes I also saw it took the log some time to report after starting ffmpeg-i (I use notepad ++ to access the log while serviio is buidling it)
mov"
    major_brand     : qt
 kb/s
Used the groovy to rename the .mov to .mp4 but still get the same problem, yet I can see nothing in the file that would prevent it from playing as it does when downloaded and played raw. Any ideas?
Post Sun Dec 18, 2011 3:47 pm
did you also change DEBUG to TRACE in
<param name="Threshold" value="TRACE"/>
Post Sun Dec 18, 2011 3:52 pm
or PM me details of the plugin so that I can run it through debugger
Post Sun Dec 18, 2011 4:10 pm
Attached
Cleeseblog.zip
(1.46 KiB) Downloaded 1219 times
Post Sun Dec 18, 2011 5:07 pm
right, so I'm getting 404 error (doesn't exist). It looks like you're always replacing .mov to .mp4 which works for most of the videos but this one, it only exists there as .mov
this works:
ffmpeg -i http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov
this does not (404)
ffmpeg.exe -i http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mp4
Post Sun Dec 18, 2011 5:20 pm
Yea, dumb of me but that was just an attempt at a workaround.
If you remove the replace line from the groovy, it will fail on the .mov file, which was my reported problem, and I know its not a 404 because i downloaded the .mov as previously posted...
How did you get the 404 output to show in the log or did you just run the ffmpeg -i on the mp4. How do we get the ffmpeg details to show in the log?
Post Sun Dec 18, 2011 6:08 pm
it does work for me
18:06:36,415 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'John Cleese Podcast #28: The Night Before Christmas'
18:06:36,415 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov
18:06:36,415 DEBUG [ProcessExecutor] Starting d:\java\workspace\serviio\\lib\win32\ffmpeg.exe -i http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov
18:06:36,415 TRACE [ProcessExecutor] Env variables: {USERPROFILE=C:\Users\Zip, PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC, TSMPATH=C:\Program Files\ThinkPad\UltraNav Utility, PROGRAMDATA=C:\ProgramData, JAVA_HOME=c:\Program Files\Java\jdk1.6.0_25\, MAVEN_HOME=d:\java\apache-maven-2.1.0\, PROGRAMFILES(X86)=C:\Program Files (x86), TFS_DIR=C:\Program Files\ThinkVantage Fingerprint Software\, TEMP=C:\Users\Zip\AppData\Local\Temp, COMMONPROGRAMFILES=C:\Program Files\Common Files, JENV_2=http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov, HOMEDRIVE=C:, PROCESSOR_REVISION=2a07, JENV_1=-i, SYSTEMDRIVE=C:, USERDOMAIN=Zip-Thinkpad, ALLUSERSPROFILE=C:\ProgramData, COMMONPROGRAMFILES(X86)=C:\Program Files (x86)\Common Files, PROGRAMW6432=C:\Program Files, PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel, SESSIONNAME=Console, TMP=C:\Users\Zip\AppData\Local\Temp, PSMODULEPATH=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\, PROCESSOR_ARCHITECTURE=AMD64, LOGONSERVER=\\ZIP-THINKPAD, PATH=C:\Program Files\Java\jdk1.7.0\jre\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Services\IPT\;c:\Program Files\Java\jdk1.6.0_25\\bin;d:\java\apache-maven-2.1.0\\bin;c:\Program Files\Mercurial\;C:\Program Files (x86)\MKVtoolnix;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\Game1X\DLLShared\, OS=Windows_NT, FP_NO_HOST_CHECK=NO, HOMEPATH=\Users\Zip\AppData\Local\Temp\, TVT=C:\Program Files (x86)\Lenovo, COMSPEC=C:\Windows\system32\cmd.exe, PROMPT=$P$G, PROCESSOR_LEVEL=6, COMMONPROGRAMW6432=C:\Program Files\Common Files, PROGRAMFILES=C:\Program Files, LOCALAPPDATA=C:\Users\Zip\AppData\Local, COMPUTERNAME=ZIP-THINKPAD, NUMBER_OF_PROCESSORS=8, EMC_AUTOPLAY=C:\Program Files (x86)\Common Files\Roxio Shared\, PUBLIC=C:\Users\Public, SYSTEMROOT=C:\Windows, USERNAME=Zip, APPDATA=C:\Users\Zip\AppData\Roaming, WINDIR=C:\Windows}
18:06:37,977 TRACE [OutputTextReader] ffmpeg version 0.9, Copyright (c) 2000-2011 the FFmpeg developers
18:06:37,977 TRACE [OutputTextReader]   built on Dec 13 2011 20:46:11 with gcc 4.4.2
18:06:37,977 TRACE [OutputTextReader]   configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
18:06:37,977 TRACE [OutputTextReader]   libavutil    51. 32. 0 / 51. 32. 0
18:06:37,977 TRACE [OutputTextReader]   libavcodec   53. 42. 0 / 53. 42. 0
18:06:37,977 TRACE [OutputTextReader]   libavformat  53. 24. 0 / 53. 24. 0
18:06:37,977 TRACE [OutputTextReader]   libavdevice  53.  4. 0 / 53.  4. 0
18:06:37,977 TRACE [OutputTextReader]   libavfilter   2. 53. 0 /  2. 53. 0
18:06:37,977 TRACE [OutputTextReader]   libswscale    2.  1. 0 /  2.  1. 0
18:06:37,977 TRACE [OutputTextReader] Seems stream 1 codec frame rate differs from container frame rate: 5994.00 (5994/1) -> 29.97 (2997/100)
18:06:37,977 TRACE [OutputTextReader] Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov':
18:06:37,977 TRACE [OutputTextReader]   Metadata:
18:06:37,977 TRACE [OutputTextReader]     major_brand     : qt
18:06:37,977 TRACE [OutputTextReader]     minor_version   : 537199360
18:06:37,977 TRACE [OutputTextReader]     compatible_brands: qt
18:06:37,977 TRACE [OutputTextReader]     creation_time   : 2007-12-21 17:54:44
18:06:37,977 TRACE [OutputTextReader]   Duration: 00:04:16.25, start: 0.000000, bitrate: 1045 kb/s
18:06:37,977 TRACE [OutputTextReader]     Stream #0:0(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, s16, 191 kb/s
18:06:37,977 TRACE [OutputTextReader]       creation_time   : 2007-12-21 17:58:52
18:06:37,977 TRACE [OutputTextReader]       handler_name    : ?Apple Alias Data Handler
18:06:37,977 TRACE [OutputTextReader]     Stream #0:1(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 320x240, 850 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
18:06:37,978 TRACE [OutputTextReader]     Metadata:
18:06:37,978 TRACE [OutputTextReader]       creation_time   : 2007-12-21 17:58:52
18:06:37,978 TRACE [OutputTextReader]       handler_name    : ?Apple Alias Data Handler
18:06:37,978 TRACE [OutputTextReader] At least one output file must be specified
18:06:37,980 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov' in the cache (online_technical_metadata), returning it
Is the episode 28 the only one failing?
Post Sun Dec 18, 2011 6:35 pm
Yes just the #28 which is the only .mov
OK.. found the problem..its with ffmpeg distributed with beta3 (31480)
It hangs on the .mov as follows.
I use 33591 for my ffmpeg command and it works fine as previously posted. I'll check with beta 4 just arrived, thank you!
C:\Users\John>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i "http://funkwar
ehouse.com/jcpods/john_cleese_podcast_28.mov"
nfig
[mov,mp4,m4a,3gp,3g2,mj2 @ 01408d80] stream 0, offset 0x30: partial file
[mov,mp4,m4a,3gp,3g2,mj2 @ 01408d80] Could not find codec parameters (Audio: aac
, stereo, s16, 191 kb/s)
[mov,mp4,m4a,3gp,3g2,mj2 @ 01408d80] Could not find codec parameters (Video: h26
4, 850 kb/s)
http://funkwarehouse.com/jcpods/john_cleese_podcast_28.mov: could not find codec
 parameters
Post Mon Dec 19, 2011 12:57 am
All fixed with beta 4's ffmpeg update. Closed
Return to Plugin development
