Plugin revision
Post Sat Feb 18, 2012 11:04 pm
Plugin revision
Hey guys I am getting ready to start on the plugin part of the repository. I would like to have some way of getting the version of the plugin. Can we get a uniform way that everyone can use to document the revision of the plugin they create?
Is there a way to put a tag in the plugin, that can be check easily? Or if there is not, maybe we can put in a comment at the beginning that has the version number.
Post Sun Feb 19, 2012 11:37 am
Re: Plugin revision
Java supports @version tag in the JavaDoc comments so that could be used. How do you want to use that in the API?
Post Sun Feb 19, 2012 3:21 pm
Re: Plugin revision
I was thinking about either having it in the plugin field. ie "livefeed.groovy 1.2" Or maybe a second field with just the "1.2" for version 1.2. Either way it we can set it up so that the API will download the newest version of the plugin.
Post Sun Feb 19, 2012 6:09 pm
Re: Plugin revision
yes, I'd say get the latest.
Post Sun Feb 19, 2012 8:22 pm
Re: Plugin revision
What should I set up in the field? x.y.z like you are doing with serviio or will x.y be enough?
Update. The more I think about it, the more I think I will let this be an open field and each developer will use what ever way he wants, as long as you can tell the progression of revisions.
Post Sun Feb 19, 2012 10:39 pm
Re: Plugin revision
I'd make it just an integer, ie 1, 2, 3, etc
Post Sun Feb 19, 2012 11:31 pm
Re: Plugin revision
true that would be easier for everyone.
Return to Plugin development
