Error playing LONG RTMP links !
Moderator: martyn
popeyeg
Post Sat Jun 23, 2012 2:50 pm
I understand that some of the links expire. But these one worked in VLC Player but not via serviio. What I am missing ?
Is Serviio not compatible to play long format as below ? or how to make it work ?
I have ubuntu 12.04 and installed all the plug-ins (ffmpeg, rtmpdump, x264), also have groovy in the plug0in folder.
any advice appreciated.
rtmp://$OPT:rtmp-raw=rtmp://38.96.175.173:1935/live playpath=00010.stream swfUrl=http://veohcast.tv/veohcast.tv.swf pageUrl=http://www.veohcast.tv/videoV.php?n=00010.stream
Post Sun Jun 24, 2012 5:00 am
Re: Error playing LONG RTMP links !
VLC is unable to open the MRL 'rtmp://$OPT:rtmp-raw=rtmp://38.96.175.173:1935/live playpath=00010.stream swfUrl=http://veohcast.tv/veohcast.tv.swf pageUrl=http://www.veohcast.tv/videoV.php?n=00010.stream'. Check the log for details.
Incorrect rtmp url format. Regardless the link is invalid now.
RTMP_Connect0, failed to connect socket. 10060 (Unknown error)
: Operation not permitted
popeyeg
Post Sun Jun 24, 2012 5:28 am
I see. But can we even play such long URL ? if its valid ?
can you point out what's wrong in the format or points me towards post where I can follow the correct format ?
I am trying to find all the Indian channels but somehow they are all invalid or have such long format that I suspect it can not be supported
Post Sun Jun 24, 2012 1:52 pm
Do not put "'rtmp://$OPT:rtmp-raw=" in front of the rtmp:// link.
popeyeg
Post Tue Jun 26, 2012 1:24 am
New question: Below are the 2 working links that play fine in VLC player. But it won't even show up in the Serviio.
can some one help what I am missing here ?
### 9x Jalwa #####
rtmp://210.210.27.37/live/ playpath=9xjalwa3 swfUrl=http://www.9xjalwa.in/livetv/jalwa.swf pageUrl=http://www.9xjalwa.in/livetv.aspx swfVfy=true live=true
Below is the log.
2012-06-25 20:17:08,477 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-25 20:17:08,579 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-25 20:17:08,717 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-25 20:17:08,721 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-25 20:17:09,668 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://210.210.27.37/live/ playpath=9xjalwa3 swfUrl=http://www.9xjalwa.in/livetv/jalwa.swf pageUrl=http://www.9xjalwa.in/livetv.aspx swfVfy=true live=true. It might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException Unknown video file type
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
Link 2 ### 9xM News
rtmp://cdn.m.yupptv.tv:1935/liveorigin Playpath=newsx1 swfUrl=http://cdn.freedocast.com/player-octo/yume/v5/infinite-hd-player-YUPPTV.SWF pageUrl=http://www.yupptv.com
Log # 2
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException:Unknown video file type
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
Post Tue Jun 26, 2012 2:17 am
Both links are fine... did you add them as livestreams?
popeyeg
Post Tue Jun 26, 2012 3:00 am
I did !
What else to look for ? any commands to debug ?
Post Tue Jun 26, 2012 3:37 am
You could turn on detailed logging but as I said they play fine. Just add those links in the console as livestreams.
popeyeg
Post Tue Jun 26, 2012 11:32 am
jhb50 wrote:You could turn on detailed logging but as I said they play fine. Just add those links in the console as livestreams.
it doesn't even show up on my TV. I guess something didn't install correctly
But I should point out that I do have other live streams that are working just fine.
microbyte
Post Mon Mar 25, 2013 6:06 pm
I confirm that I've already had trouble with some RTMP streams.
I've noticed something in common, which is a "pageUrl" parameter that contains an equal symbol! My suspect is some bug parsing the RTMP parameters because you'll have something like: rtmp://**/ app=** pageUrl=**=**
Post Tue Mar 26, 2013 1:08 am
Valid pageUrls do not contain = characters.
microbyte
Post Tue Mar 26, 2013 11:03 am
I'm sorry, but I've came across multiple links with GET parameters in the page url, by inspecting the handshake in wiresharhk. Removing everything after the "?" did not solve.
MAX_IQ
Post Mon Nov 04, 2013 5:05 pm
this syntax is for a program called Simpletv it plays most of the live streams under windows, one of the best programs, if the developer would add for it the ability to restream what it plays, it would have made from it a super star program, make sure to omit the rtmp://$OPT:rtmp-raw= part from all the simpletv links before adding it to servio
niyamneel
Post Tue Jan 30, 2018 11:58 am
popeyeg wrote:I understand that some of the links expire. But these one worked in stock video clips VLC Player but not via serviio. What I am missing ?
Return to Video feeds
