itunes audio
evanslee
Post Tue Sep 27, 2011 10:07 pm
itunes audio
h20
Post Tue Aug 02, 2016 11:34 am
Re: itunes audio
Find myself using iTunes less and less over the years. One of my favourite features on iTunes was listening to the celebrity playlists. Found lots of great music I didn't know about that way, particularly from artists I liked. And there was also a whole section of user curated playlists that had some good selections. Gradually the playlists got buried by all the album artwork (if both playlist features are still there, I can't see them). Now the store just looks like a mess :|
Torence
Post Wed Dec 06, 2017 8:44 am
Re: itunes audio
If you want to play iTunes music on non-Apple devices, you have to remove DRM protection at first. All iTunes Audios are encrypted with DRM protection, it can be played on Apple devices only. Fortunately, there are many DRM removal tool for us to remove DRM protection and convert iTunes audios from M4P to common MP3, AAC, M4A, M4B, etc. The tool for me is DRM Audio Converter for Mac. It is designed to convert DRM protected Audios at 30x faster speed with no quality loss. Good luck to you.
Learn more:
Convert iTunes movies from M4V to MP4
Post Wed Dec 06, 2017 11:19 am
Re: itunes audio
Apple no longer includes DRM on their music files. Videos, yes. But the music files are now DRM-free.
caddiesytgvwo
Post Thu Aug 22, 2019 11:43 am
Re: itunes audio
The iTunes songs which are bought before 2012 are protected with DRM. If you'd like to download Apple Music to play on any other devices, you can try to [link removed by admin] remove drm from apple music.
By doing that and converting the iTunes drm songs to MP3, you will be able to enjoy the files on any devices.
Post Fri Aug 23, 2019 1:11 am
Re: itunes audio
You can choose to replace any DRM protected music within iTunes. No need to convert anything.
Return to Audio feeds
