Philips 3208 help
tbudic
Post Mon Jan 20, 2014 9:35 am
Philips 3208 help
Hi everyone,
im new servio user and impressed with this media server.
Found solution for every problem i had on this forum, but now i m kind of stuck and have two questions.
1. my philips tv 42pfl3208 does not support external subtitles via dlna so i have to manually remux my mostly mkv containers to add titles or enable burned in titles in serviio console to transode.
I would like to avoid transcoding for codecs my TV already has so my question is: is there a way to Serviio do only remuxing (like i am doing manually with MKVMERGE=5 mins) and not re-encode
2. in online sources among other, i am trying to watch streams from my SAT TV receiver. i works only with PHILIPS 2009 profile. In profiles xml i dont se <online transcoding> section fot this profile.
does that mean stream is sent to my TV in native codec or is it somekind of inherited online transcoding rule. my question: how to combine phillips2010 profile for local and philips2009 for online transcoding
thank you
one more info if matters: using serviio on Synology DS214play
hope everyone understood my english
regards
Tomislav
Iveky
Post Mon Jan 20, 2014 2:50 pm
Re: Philips 3208 help
add online transcoding section from profile a to profile b.
pozdrav
tbudic
Post Mon Jan 20, 2014 5:12 pm
Iveky wrote:add online transcoding section from profile a to profile b.
pozdrav
thanks/hvala
but in profile that works (philips2009) there is no online transcoding section at all, that was my question
so i deleted whole <online transcoding> </online transcoding> in Philips2010
but no luck: media not suported / and my Sat tv receiver blocks
log is atached
maybe someone can help me assemble right online transcoding profile
codecs that are in sat tv stream (according to VLC) :
HD chanels: h264 (MPEG-4 AVC), ac3 (a52)
sd chanels: mpgv(MPEG1/2), mpga(MPEG AUDIO 1/2/3)
192.168.1.21 is Sat TV receiver,
192.168.1.241 is PHilips TV
192.168.1.99 is Serviio
pozdrav :)
serviio.zip
(17.92 KiB) Downloaded 820 times
Return to Philips
