Problems with subtitles.
danielaugusto
Post Mon Apr 01, 2013 4:16 pm
Hello everyone!
I have a Philips 32PFL4007D installed cable in my network. I'm using the program with the standard config. The videos with subtitles are recognized and functioned normally. Already the videos without subtitles are not recognized. But if I create a caption file until they are recognized and come to play normally (tested on files avi, mp4, mov). Does anyone know what might be happening? Do not want to have to create subtitles files for all my videos! :|
My Profile
profiles.xml
(91.71 KiB) Downloaded 1370 times
Config Subtitles
slyguy42o
Post Mon Apr 01, 2013 5:15 pm
Re: Problems with subtitles.
just so i am clear on what your saying, the video doesn't show up on your client unless you have a subtitle file for it?
danielaugusto
Post Mon Apr 01, 2013 5:32 pm
Yes, strange as it seems! I need to generate a srt file for the video to be recognized. And to make it work (in case, give play) srt file needs to have some information in it (In this case, the actual captioning).
slyguy42o
Post Mon Apr 01, 2013 7:06 pm
I would try turning off the burned sub option to see if it makes a difference.
danielaugusto
Post Mon Apr 01, 2013 8:35 pm
If I disable "burned in subtitles", both videos with subtitles and videos without subtitles are not recognized
slyguy42o
Post Mon Apr 01, 2013 10:17 pm
that is really strange, can you post a detailed server log please?
danielaugusto
Post Tue Apr 02, 2013 12:15 am
Where do I find this file? (Which folder?)
slyguy42o
Post Tue Apr 02, 2013 2:31 pm
danielaugusto
Post Tue Apr 02, 2013 4:27 pm
(319.12 KiB) Downloaded 1411 times
Post Tue Apr 02, 2013 9:01 pm
You are using Generic LNA profile, use one of the Philips profiles. You can see the files with subs because they are transcoded to mpeg2.
danielaugusto
Post Sun Apr 07, 2013 9:48 pm
Is the profile 2009 served to me. Thanks Zip
LDSPincha
Post Fri Mar 28, 2014 10:05 pm
Hi there! I have the same TV pfl4007d and already downloaded your profiles file. I am using the Philips 2009 profile and whenever i check hardcoded subs, I get invalid file format. Any thoughts?
Thanks for any help!
Return to Philips
