Status for library refresh?
angelspawn
Post Fri Aug 11, 2017 9:29 am
would it be possible to get the status of the libary refresh visible in the console as I can hit the refresh button but don't see if it's still running.
angelspawn
norm
Post Sat Aug 12, 2017 11:17 am
Re: Status for library refresh?
It was possible to see in previous releases but this was removed when Serviio received updates from the os when files were added. You have to look in the logs but it's not a user friendly.
Sent from my HTC One M9 using Tapatalk
angelspawn
Post Mon Aug 14, 2017 12:32 pm
Hi Norm,
thanks for your reply, but how can I check the logs when i'm on the new console on a different box?
Best regards
angelspawn
Post Mon Aug 14, 2017 1:07 pm
angelspawn wrote:Hi Norm,
Best regards
angelspawn
Unfortunately, you can only see the logs if you have access to the Serviio install location, which usually means from the computer that Serviio is installed on. If it's a Linux box or a NAS, you can usually use something like SSH to access the install folders, but with Windows you'd have to share the install location, and that's not an easy task for someone who isn't comfortable messing with folder sharing and permissions setting.
angelspawn
Post Thu Aug 17, 2017 12:45 pm
Hi atc98092,
couldn't the console offer a Log Tab and open the file as it has access to it, so there would be no workaround like ssh needed?
Best regards
angelspawn
Return to Feature requests
