Subtitle file charset on the fly conversion
sefo
Post Mon Jan 24, 2011 9:54 pm
zip, could you please add support for on the fly subtitles charset conversion ?
I have all SK/CZ subtitles in windows-1250 encoding on my DLNA server and I'm using serviio with 2 TVs. Samsung TV supports only windows-1250 and Panasonic Viera supports only Latin2 (ISO-8859-2) character set for central European characters.
So I cannot convert subtitle files directly on the server, because they still will be not working correctly on the both TVs.
Currently I'm using the following ugly hardcoded patch for on the fly conversion for Panasonic TV. But I think better way would be to add new parameter for that in the TV profile.
For example:
<SubtitlesCharsetConversion sourceCharset="windows-1250" destinationCharset="ISO-8859-2" />
If the element will be defined then serviio automatically convert charset from sourceCharset to destionationCharset on the fly.
If it won't be defined for TV then the subtitles are not converted.
package org.serviio.delivery;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStreamWriter;
import org.serviio.dlna.MediaFormatProfile;
import org.serviio.dlna.UnsupportedDLNAMediaFileFormatException;
import org.serviio.library.service.SubtitlesService;
import org.serviio.util.FileUtils;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class SubtitlesRetrievalStrategy
  implements ResourceRetrievalStrategy
  private static final Logger log = LoggerFactory.getLogger(SubtitlesRetrievalStrategy.class);
  public DeliveryContainer retrieveResource(Long mediaItemId, MediaFormatProfile selectedVersion, Client client, boolean markAsRead)
    throws FileNotFoundException, IOException
    File subtitleFile = SubtitlesService.findSubtitleFile(mediaItemId);
    if (subtitleFile == null) {
      throw new FileNotFoundException(String.format("Subtitle file for media item %s cannot be found", new Object[] { mediaItemId }));
    log.debug(String.format("Retrieving Subtitles for media item with id %s", new Object[] { mediaItemId }));
    ResourceInfo resourceInfo = retrieveResourceInfo(mediaItemId, subtitleFile, client);
    DeliveryContainer container;
    if (client.getRendererProfile().getId().equals("12")) {
       InputStreamReader sr = null;
       OutputStreamWriter sw = null;
       try {
          sr = new InputStreamReader(new ByteArrayInputStream(FileUtils.readFileBytes(subtitleFile)), "windows-1250");
          StringBuffer sb = new StringBuffer();
          char[] chars = new char[2048];
          int numRead = 0;
             while ((numRead = sr.read(chars)) > 0) {
                sb.append(chars, 0, numRead);
          sr.close();
          String s = sb.toString();
          s = s.replace("<b>", "");
          s = s.replace("<i>", "");
          s = s.replace("<u>", "");
          s = s.replace("</b>", "");
          s = s.replace("</i>", "");
          s = s.replace("</u>", "");
          ByteArrayOutputStream os = new ByteArrayOutputStream();
          sw = new OutputStreamWriter(os, "ISO-8859-2");
          sw.write(s);
          container = new StreamDeliveryContainer(new ByteArrayInputStream(os.toByteArray()), resourceInfo);
       catch (Exception e) {
          throw new IOException(String.format("Subtitle file for media item %s cannot be converted", new Object[] { mediaItemId }));
        finally {
           if (sr != null) {
              sr.close();
           if (sw != null) {
              sw.close();
    else {
       container = new StreamDeliveryContainer(new ByteArrayInputStream(FileUtils.readFileBytes(subtitleFile)), resourceInfo);
    return container;
  public ResourceInfo retrieveResourceInfo(Long mediaItemId, MediaFormatProfile selectedVersion, Client client)
    throws FileNotFoundException, UnsupportedDLNAMediaFileFormatException
    log.debug(String.format("Retrieving info of Subtitles for media item with id %s", new Object[] { mediaItemId }));
    return retrieveResourceInfo(mediaItemId, subtitleFile, client);
  private ResourceInfo retrieveResourceInfo(Long mediaItemId, File subtitleFile, Client client)
    ResourceInfo resourceInfo = new SubtitlesInfo(mediaItemId, Long.valueOf(subtitleFile.length()), client.getRendererProfile().getSubtitlesMimeType());
    return resourceInfo;
Samsung LE40C550J1W | Panasonic TX-P42G20E | Serviio 0.5 beta 5 | Windows 7
sefo
Post Mon Jan 24, 2011 10:00 pm
Re: Subtitle file charset on the fly conversion
Also in my code you can see that I'm trimming subtitles formating tags ("<b>", "<i>", ...) because some TVs doesn't support them.
So maybe It would be fine to add one more element in TV profile for that.
For example: <SubtitlesFormatingSupported>true|false</SubtitlesFormatingSupported> or <SrtFormatingSupported>true|false</SrtFormatingSupported>
But this is not such important request for me as the first one. :)
Post Mon Jan 24, 2011 10:11 pm
this would mean that all your files have to be in windows-1250, if you had just 1 file in other encoding it would not work, right?
Did you try encoding the files in UTF-8?
sefo
Post Tue Jan 25, 2011 7:43 pm
zip wrote:this would mean that all your files have to be in windows-1250, if you had just 1 file in other encoding it would not work, right?
yes, you are right, but it's still better to have unreadable only 2-3 subtitle files (which have another encoding as the default one) as to have unreadable all subtitle files.
zip wrote:Did you try encoding the files in UTF-8?
Yes, I did. It didn't work, Panasonic Viera supports only Latin1(ISO-8859-1), Latin2 (ISO-8859-2) and Cyrillic encoding.
lagunaa
Post Sun Jan 31, 2016 2:44 pm
I have a lot of subtitles with different character encoding, so a single character encoding value in the Serviio console is not enough...
If I change the subtitle character encoding in the Serviio console on-the-fly, then I have to stop the Serviio service to get the new character encoding active for the current video stream.
It would be useful if changing the subtitle character encoding will stop the current video streaming and restart it with the new settings.
lagunaa
Post Tue Feb 16, 2016 8:54 pm
According to http://serviio.org/index.php?option=com ... icle&id=33, we have to use the character encodings available for libiconv:
When using hardsubs, Serviio gives you, however, the option to specify the file's character encoding, so that it renders correctly on the video stream. Enter the character encoding to the Subtitle character encoding field (e.g. cp1256 for Arabic). You can find available encodings in the libiconv page.
It could be useful to make the Subtitle character encoding field an auto complete field to propose all these valid values.
Cheers.
Post Wed Feb 17, 2016 7:45 pm
lagunaa
Post Sun Mar 06, 2016 5:28 pm
zip, any chance on this?
lagunaa wrote:If I change the subtitle character encoding in the Serviio console on-the-fly, then I have to stop the Serviio service to get the new character encoding active for the current video stream.
Thanks in advance.
Post Mon Mar 07, 2016 8:56 pm
lagunaa wrote:zip, any chance on this?
Thanks in advance.
It should not be thew case. It should pick up the current value stored in the console.
lagunaa
Post Sat Mar 12, 2016 8:06 pm
Nope... If I had an active video stream before I changed the character encoding in the console, then I have to stop the Serviio service to get the new character encoding picked up for also that video stream.
Post Mon Mar 14, 2016 12:30 pm
Ah ok... that's because the transcoded file has already been created I guess.
lagunaa
Post Wed Mar 16, 2016 7:20 pm
So, I would suggest an enhancement to stop the current video streaming and restart it with the new subtitle character encoding when settings has been changed by user.
Post Thu Mar 17, 2016 9:07 am
In 1.6.1 you will be able to just click the Stop server button in the console, which will kill any running ffmpeg too. After you start the server again it will create a new file.
lagunaa
Post Wed Jul 06, 2016 12:27 pm
lagunaa wrote:It could be useful to make the Subtitle character encoding field an auto complete field to propose all these valid values.
zip wrote:Good idea, created ticket: https://bitbucket.org/xnejp03/serviio/i ... setting-in
I see ticket 872 related to subtitles character encoding has been resolved, but this similar ticket 929 has no version set yet.
Any ETA on this?
Thanks in advance.
lagunaa
Post Wed Aug 03, 2016 9:40 am
lagunaa wrote:I see ticket 872 related to subtitles character encoding has been resolved, but this similar ticket 929 has no version set yet.
Any ETA on this?
Now I see ticket 929 marked as WON'T FIX. In my opinion, it could still be a useful feature for users.
On that ticket zip wrote:
zip wrote:With the automatic detection of encoding this should be pretty useless now
https://bitbucket.org/xnejp03/serviio/issues/929/typeahead-for-subtitle-encoding-setting-in#comment-29026296
but we still have to use only the character encodings available for libiconv...
Cheers.
lagunaa
Post Thu Sep 15, 2016 10:05 am
Bump after v1.7 released.
lagunaa
Post Wed Mar 14, 2018 9:34 am
Every time I need to change subtitles character encoding I wonder why ticket 929 had been closed... :roll:
Post Wed Mar 21, 2018 2:59 pm
doe it not guess the encoding automatically?
Return to Feature requests
