Block Metadata to specific devices
Morley71
Post Sat Jul 14, 2018 5:24 am
Is it possible to get an option to block metadata to specific devices.. Metadata works great on all but FetchTV (or at least mine).. If i enable meta data only a few movies show on the FetchTV and the DVD cover flashes contantly. I name my movies with filebot and keep it simple (title (year).ext), the metadata is great in the mediabrowser and other devices but it would be good if there was an option in the status screen to block metadata (or a profile that could be selected).
Post Sun Jul 15, 2018 2:20 am
Re: Block Metadata to specific devices
I suggest you also post it on Bitbucket. https://bitbucket.org/xnejp03/serviio/issues
Morley71
Post Sun Jul 15, 2018 9:43 am
Thank you - done
Return to Feature requests
