Include Last-Modified in HTTP response headers
volley
Post Sat Nov 17, 2018 7:08 pm
While fiddling with a new project involving a UPnP client I noticed that Serviio does not include the "Last-Modified" header in its HTTP responses.
This post is a feature request to have it included, when reasonable and feasible (e.g. for local files but perhaps not for external resources).
For reference, check out section 2.2 in RFC 7232. Snapshot:
https://tools.ietf.org/html/rfc7232#section-2.2
2.2. Last-Modified
The "Last-Modified" header field in a response provides a timestamp
indicating the date and time at which the origin server believes the
selected representation was last modified, as determined at the
conclusion of handling the request.
Last-Modified = HTTP-date
An example of its use is
Last-Modified: Tue, 15 Nov 1994 12:45:26 GMT
2.2.1. Generation
An origin server SHOULD send Last-Modified for any selected
representation for which a last modification date can be reasonably
and consistently determined, since its use in conditional requests
and evaluating cache freshness ([RFC7234]) results in a substantial
reduction of HTTP traffic on the Internet and can be a significant
factor in improving service scalability and reliability.
To elaborate:
The code I am fiddling with scans the contents of the server and would in doing so like some means to figure out if a resource has changed since the last scan.
In that sense it would also be of interest to include a dc:date in UPnP ContentDirectory responses; it would spare one HTTP transaction per item in cases where no change has been made.
A HTTP ETag would also work. But neither dc:date nor ETags are part of this feature request. :)
Cheers,
volley
Post Mon Nov 19, 2018 4:27 pm
Re: Include Last-Modified in HTTP response headers
Do you need it on the Browse response or when retrieving actual resource (file)?
The browse response already includes ETag
volley
Post Mon Nov 19, 2018 6:31 pm
zip wrote:Do you need it on the Browse response or when retrieving actual resource (file)?
Ah, good point! This is when retrieving an actual resource file.
Typical URL: http://192.168.1.x:8895/resource/3332/M ... 0/ORIGINAL
As a side note I just grabbed a fresh sample of the response headers (see below) and noticed the presence of "Cache-control: no-cache". I wonder if these are related, since if caching is not allowed there might be no point in including the Last-Modified. Out of curiousity (hi-jacking my own thread here :roll:), is the presence of no-cache intentional?
null: HTTP/1.1 200 OK
Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.10
transferMode.dlna.org: Streaming
Connection: close
realTimeInfo.dlna.org: DLNA.ORG_TLAG=*
Content-Length: 2409535
Date: Mon, 19 Nov 2018 18:22:32 GMT
Content-Type: audio/mpeg
Post Mon Nov 19, 2018 7:47 pm
yes it is. I don't remember why though. Probably some renderers having problems with reusing connections etc.
volley
Post Wed Nov 21, 2018 10:11 pm
zip wrote:yes it is. I don't remember why though. Probably some renderers having problems with reusing connections etc.
Aha! I guess that should be more related to the "Connection: close" header, but I guess renderers can also have problems with caching etc.
Before I drop the request, can you see any way forward where we can both have the cookie (=support legacy renderers) and eat it (=support caching and scanning)? I'm thinking configuration options, or a "known good" list of renderers that deal nicely with Last-Modified.
Return to Feature requests
