Support and simplify high resolution artwork and metadata
Paul C
Post Fri Mar 01, 2019 11:24 am
see thread viewtopic.php?f=4&t=17870
The requirement is to "easily" support and display high resolution artwork and ensure user configuration is retained over software updates.
(Existing DLNA standard resolution option would remain untouched.)
It is presently feasible to display high-quality high resolution artwork from Serviio but is difficult to understand and implement for some users.
As a result the topic reappears periodically in the Serviio Forum - see also earlier thread viewtopic.php?f=5&t=24212
Many users it seems do not realise that they can improve/display their artwork properly which is a great shame.
The change request is to simplify this task and ensure it carries over across updates, including:-
- a new permanent Serviio Generic HD profile
- an option to customise the size for HD thumbnails (if HD profile selected) in the Serviio console
- an option to force the generation of the higher resolution artwork for existing files (if necessary).
Any other points anyone?
It would be useful to establish if the HD option works with all the other profiles - I have not encountered any issues.
Should the "Serviio Generic HD profile" become the default so Serviio users get high quality artwork out of the box?
I will then raise a BitBucket request.
See BitBucket request issue #1105 - https://bitbucket.org/xnejp03/serviio/i ... resolution
RYann
Post Sun Apr 28, 2024 1:57 pm
Re: Support and simplify high resolution artwork and metadat
The above mentioned request issue is tagged as "RESOLVED" since 2021 on the BitBucket link.
But in my Serviio-Console, I don't see any "Generic HD profile" or any of the suggestions proposed in the text.
Do I miss something?
How to take advantage of this resolved request to easily see my high resolution artwork?
Regards.
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 13 guests
