Feature Request: Settings Import/Export
Pir8pete
Post Mon Sep 22, 2025 9:40 pm
Hello, @Zip
1.) A feature request in the form of an option to save all to save all user defined custom settings in a import/export button.
2.) Another option to add to the dashboard would be to change server naming. <FriendlyName>Serviio ({computerName})</FriendlyName>
Post Mon Sep 22, 2025 11:18 pm
Re: Feature Request: Settings Import/Export
Hi Pete! We have a feature request section of the forum, so I moved your post there.
1) I know it's been requested before, but I just searched the Serviio Bitbucket site (where Zip tracks requests and updates) and didn't find one.
2) This too has been suggested, but again I could find nothing in Bitbucket. Although honestly it's not difficult to rename the server, as it's simply a line in the profiles.xml file that can be edited. Of course, when a new version of Serviio is released that file is replaced so the name must again be changed. I do it myself every time there's been an update. :)
I suggest posting your suggestions directly on Bitbucket, where it should be something Zip sees more often. Things posted in the forum can be overlooked or forgotten (as I've done in the past!
https://bitbucket.org/xnejp03/serviio/issues
Pir8pete
Post Wed Oct 15, 2025 3:23 am
atc98092 wrote:Hi Pete! We have a feature request section of the forum, so I moved your post there.
I'm talking about saving all changes for export and import. It's just more polite in the software to have a GUI for changing the server name, just like how there was a push to change the thumb res. that finally made it.
https://bitbucket.org/xnejp03/serviio/i ... ort-export
Return to Feature requests
