Categories for Audio
n3mmr
Post Fri May 13, 2011 11:59 am
Does DLNA limit what categories should be displayed??
I would really have liked to have:
Album
Composer
Soloist
Orchestra
The first two are really needed...
I listen mostly to classical and Jazz, and the current way seems best suited to light listening to easily forgotten music...
Post Fri May 13, 2011 12:38 pm
Re: Categories for Audio
You might be able to customize the categories by editing the metadata in the audio files. The following information comes from http://www.serviio.org/index.php?option=com_content&view=article&id=12
Swisscenter
Serviio supports importing XML files generated by Swisscenter media center. Using this extractor will enable you to completely manage your media library metadata via Swisscenter.
XBMC
Serviio supports importing .nfo XML files generated by XBMC. Using this extractor will enable you to completely manage your media library metadata via XBMC.
n3mmr
Post Fri May 13, 2011 12:56 pm
moltra wrote:You might be able to customize the categories by editing the metadata in the audio files. The following information comes from http://www.serviio.org/index.php?option=com_content&view=article&id=12
Swisscenter
XBMC
I think this is about metadata in a database of xml-files, and one would have to generate those.
I was wondering if the metadata embedded inside flac files could be used directly to generate categories for audio files.
Post Fri May 13, 2011 1:06 pm
I have not tried this, but the way this reads is that XBMC will generate the information.
XBMC
n3mmr
Post Fri May 13, 2011 2:01 pm
moltra wrote:I have not tried this, but the way this reads is that XBMC will generate the information.
XBMC
So... you'll have to run xbmc... and I won't, because I can't.
Or swisscenter, and thet's just the same, no can do, so no will do.
Post Fri May 13, 2011 2:14 pm
ok, Zip might have more ideas on other ways of getting it to work the way you want it to.
Post Fri May 13, 2011 3:31 pm
Return to Feature requests
