The ability to refresh specific folders/paths
tonkatrucks
Post Fri Jul 22, 2011 10:54 am
I have three folders in my library. One for music (22,000 files, 1,900 folders). One for movies (970 files, 60 folders). One for TV (6,700 files, 690 folders).
To perform a library refresh where ~5 files have changed takes about an hour.
I figure the update time would be significantly reduced if I would limit the refresh to a single path. If this were an option I might even divide my paths/folders further so that I could reduce the update time per path further. I admit I already keep relatively discreet folder paths compared to most media hoarding internet denizens :)
Post Fri Jul 22, 2011 11:02 am
Re: The ability to refresh specific folders/paths
In the console, do you try
Music Path : music on, video off, photo off, metadata x, refresh arrow on
Video Path : music off, video on, photo off, metadata x, refresh arrow off
TV Path : music off, video on, photo off, metadata x, refresh arrow off
Personnaly, all folder "refresh arrow" are default disabled, and when I want to make a refresh, only select the folder, enable "refresh arrow", save, wait end of refresh, disable "refresh arrow" and save.
But there were an open ticket about that: https://bitbucket.org/xnejp03/serviio/i ... ce-refresh
also https://bitbucket.org/xnejp03/serviio/i ... older-list
Return to Feature requests
