jpg files
pmhof
Post Fri Nov 13, 2009 11:22 am
jpg files
First thanks for this great dlna-server.
I use it for my Samsung 651 TV.
I have a little trouble with my photos (jpg-files).
Not all of the jpg-files are sent to the TV.
It has something to do with the size.
Wat are the exact specifications.
I also have the original dlna-server from Samsung; this server let me see more jpg-files (and de TV is diplaying them); it seems, that de dimensions are bigger than in your implementation.
Please help.
Post Fri Nov 13, 2009 11:47 am
Re: jpg files
HI, it's possible. DLNA spec requires the images to be max 4096 x 4096. If the image is larger Serviio doesn't pick it up. What I could (maybe ;-) ) do is resize the image to the allowed size before it's streamed.
Moving this topis into the Featuers forum.
pmhof
Post Fri Nov 13, 2009 12:18 pm
Re: jpg files
Zip,
Thanks for the quick reply.
Your solution can be an improvement, but rest my question why de Samsung en de PS3 dlna-servers both give no problems on my TV with a photo with the size of 4176 x 2938. Are the dlna-specifications strictly 4096x4096 or should it be 4096x4096= 1677216?
Post Fri Nov 13, 2009 2:53 pm
Re: jpg files
DLNA spec says max width = 4096, max height = 4096.
The other servers either scale it before streaming to the TV or send it as it is (by which they break the spec)
Post Fri Nov 27, 2009 11:09 pm
Re: jpg files
Return to Feature requests
