Web interface administration
maltmoose
Post Fri Dec 23, 2011 6:18 pm
Seriously serviio is great but it really could do with management via web interface.
I'm using ubuntu server with webmin which is really quite useful too so a webmin module would be helpful im sure
and how about a serviio package for ubuntu?
the serviio database seems slow compared to something like subsonic's which can load seemingly moments and you have access to it all.
sure some of these things are luxury items but would be nice features for any new users looking to use serviio for the fisrt time with ubuntu etc
serviio + subsonic is what im looking for :)
Post Fri Dec 23, 2011 6:23 pm
Re: Web interface administration
Check out the Third-party tools integration forum at the bottom. There are some webui's there.
Link: viewforum.php?f=17
maltmoose
Post Fri Dec 23, 2011 6:47 pm
ahh how i miss that, i'll check them out.
thanks
maltmoose
Post Fri Dec 23, 2011 9:14 pm
installed kairoh webui and seems to do exactly what i need, something like this should really be installed with serviio
adding this as a webmin module would be great, then i could do all my server management from there which would be awesome.
fwiw i also added an upstart script for ubuntu 11.10 to autostart it, seems to work ok with the limited time ive tested
start on started networking
script
/home/marc/serviio-0.6.0.1/bin/serviio-webui.sh
end script
kairoh
Post Fri Dec 23, 2011 9:47 pm
webmin module is not a bad idea, do you know any documentation about this?
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
maltmoose
Post Fri Dec 23, 2011 9:56 pm
here you go kairoh, would be great if you could put something together. another good reason to do it via webmin would be security as currently anyone on local lan could potentially access and change settings via your web interface (from what i can see) not much of an issue for your average home user though.
http://doxfer.webmin.com/Webmin/WebHome
kairoh
Post Fri Dec 23, 2011 10:36 pm
Zip prefers to let the user's choice for multiple admin tools.
At first there was some IP/network filtering, but I removed them to simplify the installation.
Same for authentication, which may be clumsy to set.
I will read about webmin.
Return to Feature requests
