MKV with embedded subtitles
Post Wed Feb 15, 2012 9:14 am
Re: MKV with embedded subtitles
Larzendk wrote:- If subtitle support is vital to you, you have a European or Canadian player, and you understand the native Matroska playback problems described above, then you can remove all matroska matches from the transcoding section of the Sony BDP device
Simply comment lines with "matroska".
Larzendk
Post Wed Feb 15, 2012 2:55 pm
Well, that is not the solution, now i can not see any of my MKV movie.
Is there any other format that support embeddet sub on serviio and runs on Sony SMP-N100?
The reasson why i like MakeMKV is that it converts very very fast
Post Wed Feb 15, 2012 5:44 pm
Larzendk wrote:Well, that is not the solution, now i can not see any of my MKV movie.
it maybe fast but its not very acuate, what would you rather a working file that take abit of time or a quick done one that fails?
Larzendk
Post Thu Feb 16, 2012 12:26 pm
Hmm you got something there, i will try to find another program to convert with, do you have any idears what works best?
Larzendk
Post Wed Feb 22, 2012 1:16 pm
Hmm. it seems that it is VOBSUB there is the problem, when a MKV has VOBSUB i can not see the subs when i run it from Serviio. On VLC it runs fine with subs.
Anything to do about this??
Post Wed Feb 22, 2012 1:47 pm
Larzendk wrote:Hmm. it seems that it is VOBSUB there is the problem, when a MKV has VOBSUB i can not see the subs when i run it from Serviio. On VLC it runs fine with subs.
This is not Serviio the problem, but your device renderer that not supports MKV with VOBSUB embedded.
Serviio simply delivered the mkv file in native format.
And when sub are is external, serviio delivered the two resource video+srt, and this is the device renderer that request resources if supported.
You have to find the good mkv format with sub embedded supported by your device renderer.
Larzendk
Post Wed Feb 22, 2012 2:07 pm
Yes, i am working on it. just now a iam trynig to make M4V with Handbrake and subs burnd in
lazybones
Post Wed Feb 22, 2012 2:37 pm
Actually serviio profiles often force transcoding on mkv files to fix device compatibility issues.
Thus having the ability to deliver the sub externally or in the video stream would still be a good feature as there are devices that support external subs but have mkv issues.
Previous
Return to Feature requests
