Serviio console does not completely shut down on exit
rombert
Post Sat Mar 03, 2012 3:59 pm
I start the Serviio Console from the terminal. When exiting using Alt-F4 or clicking the close button the process remains alive. I've attached a thread dump.
Running on OpenSUSE Linux 12.1 x86_64 , Gnome 3.2, OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode) .
serviio-console-after-exit.txt
Thread dump after exiting
(7 KiB) Downloaded 567 times
Post Sat Mar 03, 2012 11:30 pm
Re: Serviio console does not completely shut down on exit
thanks for the log, I tried to fix it from what I understand from it.... should be in the next release
rombert
Post Fri Mar 09, 2012 12:13 am
Sounds great, thank you!
Return to Feature requests
