IPTV support
Post Sat Apr 21, 2012 10:57 pm
Re: IPTV support
Ok, Mpeg4 with DivX and mp2 is not a valid DLNA profile. You could try to transcode it by replacing this
            <Matches container="mp4"/>
            <Matches container="flv" vCodec="h264"/>
             <Matches container="applehttp" vCodec="h264"/>
with
                  <Matches container="mpegts" aCodec="mp2"/>
in the generic profile's OnlineTranscoding.
o.neill
Post Sun Apr 22, 2012 11:09 am
Re: IPTV support
OK, now it shows everything I enter into a DLNA server, but in the LG player it only appers (all - MPEG2 also MPEG4), and when i want play it, LG player write: cannot play this file.
if I open Serviio DLNA server in VLC, then works streams MPEG2 ok, but MPEG4 works only audio.
what to do next?
Post Sun Apr 22, 2012 12:22 pm
Re: IPTV support
it might be due to the LG problems it has with Serviio's way of transcoding. You could confirm that by looking at the detailed log. If that's the case there is nothing I can do to help.
Previous
Return to Feature requests
