Icecast Support
CigDangle
Post Fri Jan 06, 2012 12:44 am
Icecast Support
I see that Shoutcast is supported (although I have had problems getting it to work thus far), is Icecast also supported? Nearly 15,000 streams are listed in their directory. It would be great, if Serviio supported it...
http://dir.xiph.org/index.php
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
Post Fri Jan 06, 2012 12:55 am
Re: Icecast Support
shoutcast and icecast run exactly the sme way so they should both work, althoguh i havent tried this yet.
CigDangle
Post Fri Jan 06, 2012 1:24 am
Re: Icecast Support
I tried the following streams, among others:
http://listen.eaaradio.net:8000/eaaradio64.m3u - Icecast
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1271175 - Shoutcast
Neither seem to work for me in Serviio. If anyone test these or other streams, please reply...
Post Fri Jan 06, 2012 9:28 am
Re: Icecast Support
those are playlists, you have to use the stream URL inside them, like:
CigDangle
Post Fri Jan 06, 2012 2:06 pm
Re: Icecast Support
Seems to be an issue with the PlayStation 3 and live audio streams.
I will continue on this thread:
/viewtopic.php?f=4&t=4633&p=31616#p31616
CigDangle
Post Sun Jan 08, 2012 11:56 pm
Re: Icecast Support
zip wrote:those are playlists, you have to use the stream URL inside them, like:
This works on my BDP-S370, but not my PlayStation. From everything I've read, its a profile issue.
tcviper
Post Tue Jul 24, 2012 6:21 pm
Re: Icecast Support
I have the exact same issue while adding:
http://live.fuzionradio.fm:8000/live
Works fine in VLC, serviio shows it but it wont play anything (it will open but then playback not available).
Sony KDL-55W905A | KDL-32EX521 | 32W5500 | STR-DN1040 | MacMini | Synology 1511+ | Network Cisco
Post Tue Jul 24, 2012 7:09 pm
Re: Icecast Support
Works fine for me..livestream / audio
Return to Feature requests
