Subtitle encoding on Samsung C series
vmonkey
Post Fri Jan 13, 2012 3:17 pm
I come from the Czech Republic and the most of subtitles for movies come encoded in WIN-1250 encoding. The problem is, however, that the central-european languages (such as Czech, Polish etc.) contain accents -> š, č, ť, é etc. Because Samsung TVs do handle only UTF-8 subtitles it happens that instead of "Náš svět pravděpodobně nečelil" we may see only "Nᚠsvìt pravdìpodobnì neèelil", which is not really comfortable to read. Is there an easy way to check subtitle encoding and if not correct encode it to UTF-8 to avoid manual encoding?
Thanks for help.
Post Fri Jan 13, 2012 3:30 pm
Re: Subtitle encoding on Samsung C series
vmonkey wrote:Hi,
Welcome fellow Czech ;-)
Googled this: http://www.melody-soft.com/html/unifier.html
vmonkey
Post Fri Jan 13, 2012 3:38 pm
Thanks for your answer. I know about batch conversion (and it is not a problem to write a bash script for that purpose, as I am on Linux). I just thought of an option to deal with it at all automatically without any user activity. But still thanks for your great product!
Post Fri Jan 13, 2012 4:58 pm
Encoding detection is almost impossible so I'd get it wrong in many cases. It's better for the user to deal with it.
pepa.sajdler
Post Fri Dec 14, 2012 3:52 pm
Hi, for those who use Notepad++
you don't need to download any other SW, just download a plugin called Python Script
Then in Notepad++ go to menu Plugins -> Python Script -> New Script, choose a filename and save it, then paste this:
import os;
import sys;
console.clear()
console.show()
filePathSrc="Your:\\Escaped\\Path\\"
for root, dirs, files in os.walk(filePathSrc):
   for fn in files:
      if (fn[-4:] == '.txt') or (fn[-4:] == '.srt') or (fn[-4:] == '.sub'):
         notepad.open(root + "\\" + fn)
         notepad.menuCommand(45011)
         console.write("Converting " + root + "\\" + fn+"\n")
         notepad.save()
         notepad.close()
console.write("Everything done!\n")
edit filePathSrc (don't forget to escape \ {\ -> \\} etc...), save and run - Plugins -> Python Script -> Scripts -> Your named script.
I'm not the original author of the script, I found it somwhere on the internet - so credit goes there.
22JUN2013 uodate
    UTF-8 check removed - it was causing problems (my mistake - I tried to check if the file wasn't already UTF-8 encoded, instead it switched encoding without converting in some cases...)
    It looks like the console.write is a necessity - on my machine the script would be to fast and causing problems without it (closing other open files, creating new empty ones etc...)
Return to Feature requests
