aliases for library folders
gold38
Post Fri Dec 21, 2012 1:09 pm
hello,
Firstly, great media server. Could get better :) - if:
I could give aliases to the library folders.
I have several disks with simmilar folder structure and they all show up the same in the folders view on my TV.
For example I have a Movies folder on disk-1 and disk-2. They both show plainly as Movies in the folders page on the TV.
I can't tell them apart.
I'd like to give the disk-1 folder an alias Movies1 and The other one Movies2. Problem solved.
TIA
gold
Xmantium
Post Sat Dec 22, 2012 5:16 am
Re: aliases for library folders
Hmmm... i see your point, the quick fix would be renaming the actual folders yourself, that way on Serviio it can show as Movies 1, Movies 2 ect
There is a ticket for this to be implemented but shows as "wont fix" - https://bitbucket.org/xnejp03/serviio/i ... ng-folders
@zip - not the first user to mention this. We do have this feature to rename Online Sources but not for local folder
Return to Feature requests
