Destroy ServiioService.exe process when server stopped
wassy
Post Sun Jan 03, 2010 2:30 pm
Im not sure this will be high up on anyones priorities as if you really want you can just kill the service in Taskmanager but would it be possible to actually start and stop the serviioservice.exe process when you press the "start / Stop Server" buttons on the console, just myself and perhaps other people may like to keep their RAM signature low for gaming and whatever and it seems when you stop the server, the process still persists in the background despite not being able serve files any longer.
I use Jamcast to stream audio, podcasts / my soundcard output to DLNA TV and its Start / Stop options actually shut down / restart the jamcastserver service each time as opposed to leaving it running.
Post Sun Jan 03, 2010 2:47 pm
Re: Destroy ServiioService.exe process when server stopped
The buttons are there to pnly start/stop the UPnP server. If you want to stop the service itself you can do it via the Services console in Windows, you can even change the startup option from automatic to manual if you don't want the service to start when Windows boots up.
http://www.jasonn.com/turning_off_unnec ... windows_xp
Return to Feature requests
